help w/ datalogs and spinning
I'm trying to figure out what I need to look for on the datatlogs (s300) to figure out if I'm spinning and over powering the slicks. My short times are really weak. Car is fully built 18k 12k springs, traction bar, 6 pt cage. Chassis previously went 9.85@155 from other owner. Just looking for a little insight into how to read my datalogs, correctly
check vss vs. rpm. if your vss in your log isnt linear for the most part, you are spinning the tires or the clutch. post up a log and I or the guys on here can help im sure.
