car randomly turns off and wont start
Old Jul 22, 2009 | 08:04 PM
CapnKrunch's Avatar
Default car randomly turns off and wont start
i am throwing a cel its 15 for the ignition output signal. i havent been able to drive my car in days because everytime i am able to turn it on it runs for about 5-8 mins and then turns off on its own and then it just cranks over and doesnt start but after i leave it for 2 hours it will start again and do the same thing. any idea whats wrong?
Old Jul 22, 2009 | 08:40 PM
vtecsi00's Avatar
Default Re: car randomly turns off and wont start
you car could have possibly jumped time. Have you check to see if everything Is at top dead center??? Have you replaced your timing belt recently???
Old Jul 22, 2009 | 11:36 PM
CapnKrunch's Avatar
what does that mean? lol. well i have recently had a friend fix my timing and he said it was a tooth off retarded.
Old Jul 23, 2009 | 10:10 PM
CapnKrunch's Avatar
bump for help
Old Jul 24, 2009 | 06:43 AM
92ehatch's Avatar
this is for a code 15, ignition output signal, from the helms manual.
disconnect 2p connector from dizzy, with igntion switch turned to on
measure voltage between the black/yellow(+) and body ground.
is there battery voltage? yes? continue...no? fix open in blk/yel and ingition switch
continued.
reconnect 2p connector, turn ignition switch to on.
test voltage between A21 (+) and A22 (+) with A26(-) on the ECU
is there 10v? yes? substitute known good ecu and retest....no? replace ignitor unit or repair short between yel/grn wire and ecu A21 or A22.
note: if there is a short the ignitor may be damaged
now my best guess, since the ignitor unit is notorious for going bad in these things, i would go ahead and source one out and replace it
aandrewcc
Oct 29, 2009 09:30 PM
96integrals1505
Aug 27, 2006 03:38 PM
Mark D. Surface
Jan 31, 2005 12:15 PM
ActiveAero
Sep 27, 2004 10:33 AM
Honda Virgin
Jun 2, 2004 12:34 PM
