Checked my ROD bearing clearances with ACL bearings...
Old Aug 23, 2002 | 10:33 AM
Sonny's Avatar
Default Checked my ROD bearing clearances with ACL bearings...
I decided to run ACL Duraglide bearings in my engine. Please see my other post for the results of the clearances check for the main bearings. This post is about the clearances for the rod bearings.
First, the pics.
#1 Rod torqued to spec with a strip of green plastigage in there
Crushed plastigage after removing the rod cap.
You can see how low the piston sits at BDC. Notchin the block was required to get the Eagle rods to clear.
All bagged up and ready to go the balancing shop...
Ok, now the numbers.
Measured Clearances
Rod #1: .0015"
Rod #2: .0013"
Rod #3: .0015"
Rod #4:. 0015"
Factory Spec
.0009" to .0016"
Service Limit
.0020"
I'm happy. Thanks to Rocket @ HondaSaver for the great price on the bearings.
Sonny
Old Aug 23, 2002 | 11:21 AM
Ri5e's Avatar
Default Re: Checked my ROD bearing clearances with ACL bearings... (Sonny)
ACL Bearings
Mine were all within spec.
Old Aug 23, 2002 | 05:24 PM
CRVRX's Avatar
Default Re: Checked my ROD bearing clearances with ACL bearings... (BG Boost)
Just a Question , Why would you not want to run Honda bearings ?
I'm not doubting ACL , Just out of interest.
Old Aug 23, 2002 | 05:25 PM
ninesecrx's Avatar
Default Re: Checked my ROD bearing clearances with ACL bearings... (CRVRX)
ACL's are cheaper, less work to get the right size, always in stock and I think are a better quality bearing....Mike
Old Aug 23, 2002 | 08:06 PM
Speed PHreak's Avatar
Default Re: Checked my ROD bearing clearances with ACL bearings... (ninesecrx)
Sounds like 3 damn good reasons to me.
bdubnyc
K Series
Aug 9, 2009 04:40 AM
dj-t
Jul 2, 2009 08:48 AM
The Si
Feb 22, 2007 12:33 PM
