Fuel pump removal help
Old Jul 22, 2009 | 05:16 PM
hamizle's Avatar
Default Fuel pump removal help
i got this far and now im stuck not sure what to do next fuel pump wont come out.
Old Jul 22, 2009 | 05:34 PM
follie gatts's Avatar
Default Re: Fuel pump removal help
Replacement
Do not smoke while working on fuel system,
Keep open flames away from your work area.
1. Remove the rear seat (see section 20) (20) (Hatchback: Remove the spare tire lid and the protective cover)
2. Remove the access panel.
3. Disconnect the 2P connector from the fuel pump.
Remove the fuel pump mounting nuts.
Remove the fuel pump from the fuel tank.
install parts in the reverse order of removal.
did you remove 3 bolts from access panel and 6 from the fuel pump assembly?
edit: http://www.team-integra.net/sections...?ArticleID=391
Old Jul 22, 2009 | 07:12 PM
hamizle's Avatar
Originally Posted by follie gatts
Replacement
i cant seem to find them, i have the three off for the access pannel but the 6 i cant see and dont even think are there. you can see from the pics
Old Jul 22, 2009 | 07:14 PM
hamizle's Avatar
and whats strange is that i see from the thread where they would be and it seems like mines completely different
Old Jul 22, 2009 | 07:24 PM
Targa250R's Avatar
be professional
Why are you pulling the fuel pump?
Old Jul 23, 2009 | 07:22 AM
89EFLS's Avatar
HEY, im having the same problem on my 93. i have the new pump, but it looks nothing like what im seeing under the access panel, the wires connections look the same, but that is about it.
Old Jul 23, 2009 | 11:50 AM
hamizle's Avatar
for the welbro 255 for boost son
Old Jul 23, 2009 | 11:51 AM
hamizle's Avatar
lol bump for us, its strange isnt it? my friends teg looked different and was much easier. im sure someone here knows.....
Old Jul 23, 2009 | 02:47 PM
89EFLS's Avatar
yeah, you would think. there are two differient connections on the new pump harness right? one goes to the plug in your pix and the other connects to the main harness. its is almost like what we are seeing under the inspection cover is the sending unit. but why would they be in differeint locations??? This is confusing
Old Jul 23, 2009 | 08:13 PM
hamizle's Avatar
haha i donno this is a bitch i feel like ripping it out
Old Jul 24, 2009 | 07:02 AM
have you guys checked out the other access panel underneath the spare tire cover? are you working on hatchbacks or sedans?
Old Jul 24, 2009 | 07:27 AM
89EFLS's Avatar
Mine is a hatch. I didnt know there was another access panel. That would make life so must easyer. Im dreading droping this tank. i just got gas... GRRR.
IM tempted to take a damn cutoff wheel to the floor...
Old Jul 24, 2009 | 08:34 AM
here's the fuel tank removal diagram from the acura service manual. from the look of this, it's under the seat, but you can see there are two access panels. maybe you guys aren't pulling enough crap out to find the pump? either way, check out the other access panel, we could be in for a surprise.
Old Jul 24, 2009 | 09:24 AM
lsturbo*'s Avatar
This picture you have here is your fuel gauge sending unit. The fuel pump in under the rear seat. Remove the rear seat by pulling (2) clips on each side of the backrests, and (1) 10mm bolt. Then the rear seat will pop off and you will see an access cover similar to the one above, but bigger. Remove that and you'll figure it our from there.
G/L
Old Jul 24, 2009 | 10:02 AM
89EFLS's Avatar
G/L
Huh, that is what mine looks like under the rear seat. But ill check the trunk after work. THANKS GUYS!!
Old Jul 24, 2009 | 12:06 PM
lsturbo*'s Avatar
Well, that is his ABS sensor shown in the picture, which is above the passenger rear brake, so it cant be the fuel tank.
Old Jul 24, 2009 | 12:15 PM
lsturbo*'s Avatar
Here is what I am talking about...Just making sure your not mixing these 2 access panels up.
Old Jul 24, 2009 | 01:04 PM
total win.
Old Jul 24, 2009 | 03:34 PM
nafreak's Avatar
He didnt say if it was a DA or a DC...
If it is a DA then you have to pull the tank to get to the pump, it cannot be accessed from under the seat, only the sneding unit is there.
Old Jul 24, 2009 | 06:16 PM
hamizle's Avatar
FUEL PUMP IS IN! thank you yes i didnt look under the seat i was mixed up what a pain lol thanks alot still getting use to honda's its much different then the rx7 world i came from.
As for MR 89EFLS i hope you got to it as well its not hard at all once you find the right access panel lol
Old Jul 24, 2009 | 11:37 PM
kroze's Avatar
hehehe
Old Jul 25, 2009 | 08:30 AM
89EFLS's Avatar
Well hell, yes, mine is a 91. A DA. So i have to drop the tank??
DAMN... that sux
Old Aug 4, 2009 | 03:39 PM
1992db2's Avatar
DAMN... that sux
yup. i know. it sucks for us DA people
Old Aug 17, 2009 | 10:26 AM
thegorgeous's Avatar
New User
i have an 87 prelude si 2.0
how can i tell if the fuel pump is under the seat or on top of the fuel tank
i`m assuming its the fuel pump thats needs to be replaced as when i turn the ignition on it continously gargles and hums.
Old Aug 17, 2009 | 02:38 PM
89EFLS's Avatar
you mean that the pump never shuts off? it should build up pressure and then shut off.
Andruw Martinez
Oct 1, 2015 06:46 PM
KevronsEG
Jul 6, 2007 02:47 PM
o2flow.net
Oct 1, 2006 08:55 AM
birds_sol_94
14
Aug 10, 2004 01:15 PM
Ragezero76
Jul 19, 2004 05:09 PM
