FS: Cheap Built NA 1999 Civic SI!
ASKING - $5,000 FIRM
IF SOMEONE COMES GETS IT BY THE END OF THE WEEK I WILL SELL $4500!!!!!!!!!!!!!!!!!!!!!!!!!!
car needs TUNED and is pulling TPS code (i dont have a voltameter) !!!!
Selling my MR EM1
150k miles on body
2k miles on bottom end
5k miles on head
NO AC, but has PS
this is a fresh rebuild, all new bearings,rings, pumps, gaskets, etc.
MODS:
b18b block - bored to 81.5mm block guarded
polished and balanced ls crank
JE pistons 12:1
eagle h beams
acl bearings
Arp Rod Bolts
Arp Head Studs
B16 head - stock port
Shunk2 intake mainfold
Shunk2 Throttle body, 68mm
Buddy Club spec 4. cam shafts
Buddy Club cam gears
Supertech springs
Shunk2 TI retainers
AC fuel rail
AEM Fuel pressure regulator
apexi exhaust world sport,
magnaflow high flow cat
short shifter
XTD Stg2 clutch w/ ACT Flywheel
Converted to OBD1
310cc Injectors
Walbro 255
KiddRacing RMF Header
Customer vented VC w/ breather can
Suspension:
15" Rota GT3's Silver/Polished - falken azenies 205/50/15
Tokico Adj Shocks
Skunk2 Coilover Sleeves
Exterior:
CTR Front Lip - black (broke i took it off)
OEM Fog Lights
Interior:
NO Carpet, original carpet was FILTHY so i took it out
STOCK great Condition
Alpine Head Unit
CAR NEEDS TUNED
the heater blower makes a gurgle noise, but works 100% A+,
BAD:
- Pulling CEL 7 - TPS (i dont have a voltameter to fix it)
- NEEDS TUNED!! - just installed the rc310's (have base from stock injectors)
- Heater Fan gurgles - havent had the dash out to check reasoning
- NO Carpet - took it out to clean it and never put it back in !!!
here is the only recent pic i have w/ my iphone!!
here is another link to some more pics, the bay has changed tho!
https://honda-tech.com/forums/appearance-build-threads-122/my-99-si-slow-dd-build-2466364/
Selling my MR EM1
150k miles on body
5k miles on head
NO AC, but has PS
MODS:
JE pistons 12:1
eagle h beams
acl bearings
Arp Rod Bolts
Arp Head Studs
Supertech springs
Shunk2 TI retainers
AC fuel rail
short shifter
Converted to OBD1
310cc Injectors
Walbro 255
Suspension:
Tokico Adj Shocks
Exterior:
OEM Fog Lights
Interior:
Alpine Head Unit
CAR NEEDS TUNED
BAD:
fly out here, if you buy it, i give you ur plane ticket back!!!!!
i also have a set of JDM Power Folding Mirror w/ switch (not installed) i will throw in
https://honda-tech.com/forums/showthread.php?t=2466364
here is a few pics, even tho the bay has changed quite a bit, everything else is the same!
jksmith
Jun 30, 2009 08:38 AM
... car is running great now, lil rich but thats just the tune!!
