fuse starts to melt....
Old Jul 21, 2009 | 11:01 PM
slammed em1's Avatar
Default fuse starts to melt....
wats up guys....my left headlight fuse keeps on burning like its melthing and it causes my left headlight, and parking lights to go off... plus wen it goes off my highbeams dim on and the right headlight workks normal....i switch the fuse and every time it does the same thing(it starts to melt)...what could this problem be? do i need a new fusebox because that sounds like the only solution.....
Old Jul 22, 2009 | 02:44 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: fuse starts to melt....
That sounds like the only solution?
1) Are you putting int he correct fuse?
2) Are you even bothering to look if you have a wiring issue. Namely things like a direct short.
Old Jul 22, 2009 | 09:56 AM
im pretty sure the fuse is going in correct....
the only wiring different in my car is that i have a wire connecting the starter to my compressor line to give my compressor electricity...but i doublt thats it
Old Jul 22, 2009 | 10:20 AM
It doesn't have to be different, if it's blowing your headlight then the headlight harness could be worn or ripped and touching other stuff.
Old Jul 22, 2009 | 10:58 AM
MissJPhatEphex's Avatar
check all related ground wires
Old Jul 22, 2009 | 08:04 PM
ima check all that in the morning....thanks for the info guys...and if this aint the problem then what should i do?
allenlavoie
Apr 23, 2012 03:34 AM
honda011
15
Nov 26, 2005 08:10 AM
John F
Aug 21, 2005 08:14 AM
GreenD16Y8
Aug 8, 2005 03:59 PM
obsidianG35
Sep 12, 2003 01:50 PM
