First build, I got a quick question. Help! Please!
Old Jul 21, 2009 | 08:28 PM
hmtcrxsir's Avatar
Default First build, I got a quick question. Help! Please!
I just rebuilt my 96 Integra GSR engine. And i've used Kings bearings. And I made sure everything is within specs with plastigauge. And I torque the bolts down to suggested torque specs using a Helms manual. But after everything I tried turning the crank with bare hands and it seems to not move a bit or other words, its hard to turn. I dont know if im doing it wrong or im missing something but I know when i took the GSR engine out. I can rotate the crank really easily with minimal force. Is this normal? Help?
Old Jul 21, 2009 | 08:55 PM
Adam_b16a's Avatar
Default Re: First build, I got a quick question. Help! Please!
what are your clearances? Did you use assembly lube?
Old Jul 21, 2009 | 10:15 PM
hmtcrxsir's Avatar
they are within 0.0015 clearance.
Old Jul 22, 2009 | 11:48 AM
hmoobhero's Avatar
so where are you turning it? crank pulley? the actual crank? whats all bolted to the crank? i remembered when i took apart my ls block, it was hard turning the crank with my bare hands and all the rods and pistons were still in the block. maybe check your bearings, they mite be backwards or your rod caps mite be backwards as well...that happened to my uncle before...and it was hard to turn it even with a breaker bar...
Old Jul 22, 2009 | 04:56 PM
-Darren-'s Avatar
no its not normal. i suggest you go double check that you put everything in right. did you put any engine break in lube on the bearings before putting the rods caps, etc back on?
Old Jul 24, 2009 | 11:00 PM
hmtcrxsir's Avatar
yes i used assembly lube on everything. bearings, bolts, etc. i just worry I might have flip the main girdle the wrong way and might mix up the main caps 1 and 5. anyone have a picture of the GSR main girdle installed properly on the block?
Old Jul 25, 2009 | 10:11 PM
hmtcrxsir's Avatar
i double checked again and still does the same thing.
nemesis.442
17
May 7, 2012 12:34 PM
eruktion
Feb 20, 2012 11:28 AM
b20beast83
30
Oct 19, 2009 12:45 PM
pdiggitydogg
Sep 4, 2005 06:48 AM
MugenB16A2
18
Dec 15, 2003 05:17 PM
