b20 vtec
okay, i just got a b20a block im going to make vtec, now to start can i use my p28 wireing harness, and if i used a b16 head what ecu do i use? btw what head would make the most power out of the b20 vtec conversion?
Another option, keep your current setup and just look for a used JR supercharger for like $800. It would make a hell of a lot more power than a vtec conversion. Not sure why everybody is so hot to have the "vtec" image...there are other choices!
LoL. I'll try to help you out a bit if you're set on a Vtec head...a lot of people like using GS-R heads because of the smaller combustion chamber. You can use your P28 ecu but I would highly recommend that you have the car tuned. A custom tune will yield the most power and best results.
full Circling
Aug 22, 2005 09:05 PM
