p72 ecu jdm or usdm?
Old Jul 21, 2009 | 03:04 PM
Luke G.'s Avatar
Default p72 ecu jdm or usdm?
i am buying a jdm b18c from hmotors, will this come with the jdm p72 ecu as well? Because i was told that if i used the usdm ecu i would have to put a vtec solenoid switch.
Old Jul 21, 2009 | 07:08 PM
MONSTERek4's Avatar
Default Re: p72 ecu jdm or usdm?
smoked out either or you have to have a solenoid how else will vtec pop playa playa
Old Jul 22, 2009 | 06:16 AM
mtber's Avatar
Incorrect. You can bypass the vtec pressure switch. So you can run a usdm or jdm ecu.
Your best bet would probably be a chipped obd1 vtec ecu.
Old Jul 22, 2009 | 10:43 AM
Luke G.'s Avatar
thanks for the reply, are you saying i can either bypass it, or run the chipped ecu? Or does the chipped ecu bypass it?
Old Jul 22, 2009 | 12:06 PM
mtber's Avatar
You may bypass the vtec pressure switch with a wiring bypass trick listed on our website http://www.phearable.net/tech
Concerning a chipped ecu, it was simply a recommendation instead of running a stock p72.
Old Jul 22, 2009 | 12:44 PM
Luke G.'s Avatar
alright thanks for the link, but if i get the jdm ecu why would i need to bypass it? Wouldnt that already be bypassed?
Old Jul 22, 2009 | 05:46 PM
mtber's Avatar
Yes, it should :-)
Old Jul 22, 2009 | 06:32 PM
MONSTERek4's Avatar
i thought he was talking about the solenoid not the vtec oil pressure
Old Jul 23, 2009 | 07:32 AM
Luke G.'s Avatar
Yes, it should :-)
alright thats what i was wondering ha, Thanks for the help.
phoxking
Apr 7, 2011 11:27 PM
phoxking
Mar 25, 2011 12:04 PM
JeffBro
Oct 9, 2005 01:50 PM
DarkTeg94
Apr 20, 2005 06:48 PM
