Blew 4 tires in a month on a gsr...NEED HELP...
Old Jul 21, 2009 | 11:27 AM
igorka_91's Avatar
Default Blew 4 tires in a month on a gsr...NEED HELP...
Hey HT
Iwe been going trough tires like a madman.
My car is a 97 gsr that is lowered on 17s with 205 40r 17 tires
I blew two brand new kuhmo ecsta tires in less then 2 weeks. Then a falken ziex tire that i put on to replace the blown kuhmo tire. This is all hapening on the front tires. The rear tires all all good.
Im tinking that mi car is droped way to much and when i take a hard corner it just puts to much load/force on the inside of the tire and they go out.
Here are some pics of what i am talking about.
The Falken tire
The kuhmo tire
The kuhmo tire
Sorry for the cell pone pics. Its all that i have to take pics with.
If you guys need a pic of how low my car is
Tell me
Thanks
Old Jul 21, 2009 | 11:33 AM
TYL3R's Avatar
Default Re: Blew 4 tires in a month on a gsr...NEED HELP...
pic of car? and it be the camber or toe being off, i blew a tire in like 2 weeks when my camber and toe were off.
Old Jul 21, 2009 | 12:30 PM
JonMaltese/LScivic's Avatar
lets see your car!!!!!
Old Jul 21, 2009 | 01:26 PM
supracrx's Avatar
is your car aligned?
Old Jul 21, 2009 | 01:50 PM
racebum's Avatar
under inflated or WAY out of alignment. if you did something stupid like slam your car and not correct for it. that's probably a BIG part of it
Old Jul 21, 2009 | 01:53 PM
90_EX_Civic's Avatar
pictures of the tread too would help
Old Jul 21, 2009 | 02:06 PM
alphalanos's Avatar
Looks like rubbing on the inside. How low is the car. I hope you got an alignment but looks like you didnt or its way too low.
Old Jul 21, 2009 | 03:47 PM
nsxtasy's Avatar
H-T Order of Merit
Yup, looks like something is rubbing on your tires. This could be caused by any number of things: lowering the car too much, using wheels with the wrong offset, bent suspension components, etc. Alignment by itself probably isn't the cause, but any time you change your car's ride height, you need an alignment. And no, it's not caused by the amount of cornering force on your tires. (Although it's possible that the tires are only rubbing when they are cornering, and rubbing IS the cause.)
The tire size (205/40-17) should work so that isn't the cause, as long as your wheels are the proper width for that tire size (7.0-8.0 inches wide). If your wheels are narrower or wider than that, that can cause tire failure also.
Improper tire pressure can also cause tire failure, but it has to be off by a LOT (like 10 psi less than, or more than, the recommended pressures of 35F/33R measured cold).
Old Jul 21, 2009 | 03:50 PM
thabao's Avatar
Wheels are to big.....
Old Jul 21, 2009 | 04:02 PM
jhammond_82's Avatar
Reject Papi
damn dude. lift that up a little bit and see what the camber looks like then.
Old Jul 21, 2009 | 04:04 PM
nsxtasy's Avatar
H-T Order of Merit
WRONG. 17" wheels (17x7, 17x7.5, or 17x8) with 205/40-17 tires do NOT cause tire failure.
Old Jul 21, 2009 | 05:45 PM
thabao's Avatar
I'm just saying but yeah, your offset and alignment are probably your issues.
Old Jul 21, 2009 | 11:02 PM
igorka_91's Avatar
As asked
Heres a pic of mi car
Old Jul 21, 2009 | 11:05 PM
igorka_91's Avatar
I know mi alignment is of because it puls to the right a good amount because i hit a curb about 2 months ago and havent had the time/money to go gett it aligned. Right now im in the proces of swaping in the oem springs back on the shoks. But i mesed up the springs and tought that the shorter springs go in the front so my car is even more slamed in the front. Like the rim almost is under the fender..Stopid me
Old Jul 21, 2009 | 11:06 PM
igorka_91's Avatar
I had mines set at 38 in the front wen i had the falken tire on and it blew ...?
Old Jul 22, 2009 | 04:58 AM
nsxtasy's Avatar
H-T Order of Merit
Measured cold, 38 is a bit on the high side (for my taste, anyway), but would not cause tire failure.
Well, that's why your tires are failing. Something in your suspension is messed up, and your tires are going to keep failing until you fix it - so it's going to be a lot cheaper for you if you get the suspension fixed, since you won't have to keep replacing the tires.
Also, an alignment may not be the only thing you need. When you hit that curb, it's possible you did damage beyond just the alignment settings; for example, you may have bent a control arm or other component(s). You need to get the car up on a lift, and someone who's really knowledgeable about suspensions needs to take a good look at all the components to see if any are damaged. AND get the car aligned properly too. Oh, and you should also take a good look at the wheels, and put them on a balancing machine; it's possible that one or more of them got bent in some way and are no longer true (perfectly round).
Old Jul 22, 2009 | 02:42 PM
igorka_91's Avatar
I replaced the LCA as sonn as i hit the curb.
Money is being an isue right now and im not driving the car that much til next month when i will have $. Meanwile im in the proces of puting the stock springs on the car. Kinda tired of not being able to go to places on a lowered car.
Old Jul 22, 2009 | 02:50 PM
racebum's Avatar
guy down the street hit a curb, bent the control arm. that prelude will eat a new tire in 5000 miles or so. bent the lower arm and the subframe it mounts to. you really should listen to nsx here and inspect the damage done. not only will your car perform better when fixed but even $60 a tire for something halfway okay and cheap like federal 595s will cost you more in a year than fixing it will.
Old Jul 22, 2009 | 03:07 PM
ahh.... putting on stock springs..... . takes me about hour and half to do the fronts and about 45 mins to do the rear. all of this with out a spring compressor too.
on another note, if you want a lowered look, go and ask one of the type-r guys if you can buy there old oem springs. will drop your car about and inch, and it's type-r stock.
Old Jul 22, 2009 | 03:18 PM
TOO MUCH TORQUE's Avatar
are you getting free replacement tires from the shop?
Old Jul 22, 2009 | 05:10 PM
igorka_91's Avatar
lol that hella long
It took me no more then 45 minutes to put them on 4 days ago when i accidentaly put on the reaer ones in the front. Using my rim as a spring compresor to compres the spring
Nah im done with lowered cars. I want a stock ride heigh car so i can go places that i usualy couldnt go like up to the mountains or when i go snowboarding in the winter.
Old Jul 22, 2009 | 05:11 PM
igorka_91's Avatar
No
I got the falkens for 10$ a tire of of CL and the kuhmos for 50 for 4 brand new tires.
Good deals
Old Jul 22, 2009 | 05:13 PM
igorka_91's Avatar
It will get fixed once i hit the alignment shop and what ever they tell me will be geting fixed or pulled out that i bent when i hit the curb.
I hit the curb more then 2 months ago.
b16-ef-si's Avatar
same happened to my sol that i slammed but mine blew cus the little bracket that holds the fender was grinding on the tire and blew 2 tires at once hahaha made it to the mall and back then booom booom hahaha
Vtec04
Jan 22, 2017 05:55 AM
90daXsi
Sep 21, 2008 04:53 PM
TOO MUCH TORQUE
Feb 8, 2007 11:57 PM
Oo azNite oO
21
Dec 4, 2004 04:54 AM
