Removing/Installing Valve Cover
Old Jul 21, 2009 | 09:47 AM
khmers0uljah's Avatar
From: I'm always painting & polishing shiet, California
Default Removing/Installing Valve Cover
So I have a 1997 B18B motor and I'm going to remove the valve cover soon. Are there any precautions I should be aware of when I remove & install it? I've done some research and some say that you should torque the bolts down to 7.2ft/lb in a sequence and such. Is there anything else I should know? Should I grab some Hondabond or can I just remove the valve cover and put it back on without any problems? Also, do the spark plugs come off if I remove them by hand or are there special tools required? Sorry for all the questions folks, I'm a big *** noob when it comes to this, but TIA!
Old Jul 21, 2009 | 10:36 AM
EnjoyTheRideDC2's Avatar
Default Re: Removing/Installing Valve Cover
Just make sure you dont stretch the gasket if it sticks to the head when pulling off. Pick up some hondabond or Permatex Grey gasket sealant to apply on the ends where the cam gears are and the areas noted in the helms. Torquing down the bolts should require a little more than a hand tight turn of the ratchet.
Spark plugs should come out with a spark plug socket, ratchet, and extension. Make sure to apply anti seize to the threads upon replacement.
Old Jul 21, 2009 | 11:41 AM
dntnedvtec's Avatar
X2
But if there was already hondabond, or permatex, you will need a new razor blade to remove anything that suck on. Good luck.
Also, if you don't have a spark plug socket, You can use a 5/16 socket to loosen the plug, and a 3/8 rubber hose to retrieve the plugs. Vise versa when installing the plugs. Plugs are torqued to 15 Lb/ft. If you don't have a torque wrench, turn it to when its hand tight, and I think its a 1/4 turn after that point should be pretty close.
Old Jul 21, 2009 | 01:45 PM
Originally Posted by dntnedvtec
X2
Thanks guys, it seems like an easy job, I just don't want to mess anything up. I take very good care of my car so I want to do everything right the first time. And yes I have a torque wrench in hand.
PunkRudeBoy
12
May 5, 2018 09:04 PM
NayborhoodJohnny
Aug 19, 2011 10:23 PM
90laser_rst
Sep 26, 2006 07:15 AM
BrianDelSol
Aug 7, 2004 06:17 PM
bigslimdog
13
Mar 10, 2004 01:33 PM
