D16z6
93 del sol si 167k miles smokes and burns oil dont know if its valve seals or piston rings someone help me
also if the car sits overnight when i start it in the morning after 10 mins it shutsoff.... after letting it sit for about 5-10 mins it starts back up and if fine for the rest of the day....... HELP
i did and it came back fine im probly going to put in a H22 swap just need to know what this is before in pretty sure its valve seals due to the compression test being ok and it also smokes all the time cold or hot
in thinking the shut off is the dizzy but im not sure
does it smoke all the time? If it is the valve seals then more than likely it will smoke when you first crank the car up and in between shifts. It will smoke like a bluish color. If it smokes black in between shifts then thats running rich, so make sure it is smoking blue. If it is smoking a greyish white then it is more than likely your rings.
Redprelude98
30
Jul 21, 2009 01:21 PM
