Do all sohc engines for 92-95 civics run on the same ecu??
Old Aug 23, 2002 | 08:20 AM
Touch's Avatar
Default Do all sohc engines for 92-95 civics run on the same ecu??
Wanna put a d16 in place of a d15, any input is welcome.
Old Aug 23, 2002 | 08:30 AM
TREVER's Avatar
Default Re: Do all sohc engines for 92-95 civics run on the same ecu?? (Touch)
no
Old Aug 23, 2002 | 08:31 AM
Spade's Avatar
Auto or Manual.....yes. P28.
Old Aug 23, 2002 | 09:36 AM
jdmitr98's Avatar
Default Re: Do all sohc engines for 92-95 civics run on the same ecu?? (TREVER)
no
Old Aug 23, 2002 | 09:42 AM
hondafrk's Avatar
Default Re: Do all sohc engines for 92-95 civics run on the same ecu?? (jdmitr98)
you will need a p28 ecu from the 92-95 ex/si.
I'm assuming you have a manual tranny so you will need to get an ecu with these numbers 32870-p28-a02 or at least make sure that the 3rd set of numbers do not have a 5 as the second number, It could be a a01, a02,l01 l02, g01, g02
not a52, g54 so on and so forth those are for the automatic.
mr_ek9
Jul 4, 2007 11:44 AM
jdm_vtec
Jun 25, 2007 03:11 AM
jdm_vtec
Jun 25, 2007 02:38 AM
jonnybravo
Feb 22, 2002 12:36 PM
