70 mm BDL tb on b18b from a b18c gsr?
I purchased a tb that I think was on a b18c gsr the guy said it would work on my b18b.
when i installed it even after I reset the tps and the idle air screw i can not get the idle
down from 2500 to 3k rpm. when i block the idle hole inside the tb the car idles down to almost normal. I guess my question is will changing out the tps and the map sensor from my stock TB help me out?
dsmarefaster
May 15, 2005 03:55 PM
