Which brand for brake rotors?
upgrade the brake size...go with a fastbrakes kit, 10.3" or 11.1" stock rotors, 94-01 integra calipers and some hawk pads. its worth every penny. its better than rocking some expensive slotted and drilled **** and not noticing any real difference.
i just bought brakes from a place on ebay called brake-overstock. new company, only has like 16 feedback. i was number 4 to buy from them. i got powerstop rotors, and powerstop organic pads for 59 bucks. and all their **** is free shipping. i'm ordering rear this week.
thanks bro.
i want to go for fastbreak but the shipping is pain in the butt
even for a swap motor, you don't need fastbrake unless you are dragging or doing heavy mods. if you are a weekend warrior and it's your dd, i'd suggest you get a better brake pads, a pair of new oem rotors and flush your system.
mine is a dd and i autox very often. i'm using generic rotors w/hawk hp+ in the front and oem rear shoes at the rear. after you flush your system and replace the old rusty rotor, you'll be amazed how the car can stop this quick.
just my 2cents.
just my 2cents.
just my 2cents.
just my 2cents.
what size of rotors you have?
thanks
Hey hey I use cheap brake rotors they cost me $35 for the pair and work great no problems
Stock size too. Just buy rebuilt master cylinder , change the fluid , put good brake pads and your good. I'm even using stock lines and drums.
Since this setup stops so damn good, I am going to upgrade to the Si front calipers, get the HP+ pads, and the Brembo blanks again. At the same time I'll be adding Stainless steel lines for even better brake feel.
There's really no reason for the Integra brakes. CRX's are so light they do not require a ton of braking force.
