Help me identify this CLUTCH noise...
Old Aug 23, 2002 | 07:55 AM
Cosworth's Avatar
Default Help me identify this CLUTCH noise...
Car: '99 DX hatch
Problem: first 1" of clutch travel, there is a clicking noise coming form the tranny/clutch.
What is starting to go wrong?
I was thinking that maybe one of the springs are taking a crap... or throwout bearing is starting to go.
No rattling noise at all, just clicking noise on the first 1" of clutch travel.
Thanks.
Old Aug 23, 2002 | 08:24 AM
dogpile5's Avatar
25 Year Member
Default Re: Help me identify this CLUTCH noise... (Cosworth)
probably the throw out bearing. does it make any noise while the pedal is not pressed?
Old Aug 23, 2002 | 10:01 AM
Cosworth's Avatar
Default Re: Help me identify this CLUTCH noise... (dogpile5)
Nope, no noise, if pedal is pressed, not-pressed. It just squeaks during the first 1" of movement.
Old Aug 23, 2002 | 10:11 AM
fowler!'s Avatar
I think I may be in the same boat.
Sometimes, when I'm not on the clutch, I can hear a small whine, like a belt is loose.
Then when I press the clutch, its a little crunchy..
Old Aug 23, 2002 | 01:12 PM
Vanilla4215's Avatar
Default Re: Help me identify this CLUTCH noise... (fowler)
If the pedal just squeaks when you press it a bit, then this is nothing to worry about. It is a spring on the pedel somewhere, not the clutch. Nothing to worry about unless the squeak really annoys you that much.
Old Aug 23, 2002 | 03:00 PM
Dr. EKology's Avatar
Default Re: Help me identify this CLUTCH noise... (Vanilla4215)
mine is like that, when the clutch isnt pressed, it makes like a little vibrating, spinning, squeeking noise. Is this bad?? What are the signs of a bad throw out bearing?
Old Aug 23, 2002 | 03:02 PM
hondafrk's Avatar
Default Re: Help me identify this CLUTCH noise... (EKology)
throwout bearing noise is made when you depress the clutch. If it whines when you press on the clutch then your throwout is bad, If it whines when you dont have your foot on the clutch then most likely your pilot bearing is bad. I think?
AussieR
Sep 4, 2016 08:30 AM
Nick Kozeski
Sep 2, 2015 02:18 PM
John Vang
Aug 15, 2013 08:03 AM
shermanyang
Dec 1, 2012 11:24 AM
