d16z6 del sol. Need Help!!!
Old Jul 20, 2009 | 09:34 PM
U_GOOD's Avatar
Default d16z6 del sol. Need Help!!!
I just picked up a 93 del sol and it has a d16z6 bottom end and i guess a non vtec head with a p28 ecu. I wanted to know what I need to do to make it vtec? Do I just find a d16z6 head and just replace and bolt on? do I need to anything else? Im a noob at this. And how can you tell if it is vtec? Any pictures would be nice. I regular drive b16 and b18 and I can tell when vtec kicks in. Thanks.
Old Jul 20, 2009 | 09:37 PM
waaBAAH's Avatar
Default Re: d16z6 del sol. Need Help!!!
so i take it your throwing a check engine light corect?
it sounds liek all that is needed is a vtec head. d16z6 or d16y8
look for a solenoid on the head behind vavle cover on the head itself on the passenger rear side to tell if it is a vtec or not.
Old Jul 20, 2009 | 09:42 PM
U_GOOD's Avatar
no there is no check engine light. What color is the plug?
Old Jul 20, 2009 | 10:10 PM
JarvisW's Avatar
Sol to Sol
Think its black or grey, but hes talking about a thing sticking off the back of the head. Its about 2-2.5" tall and 1-1.5" wide. If you dont have one, you can tell when you see one.
Old Jul 20, 2009 | 10:36 PM
U_GOOD's Avatar
Ok i found the VTEC solenoid on the head. Green Plug. But VTEC is not kicking in. What do i check for next?
Old Jul 20, 2009 | 10:59 PM
JarvisW's Avatar
Sol to Sol
Then it is a Z6 or Y8 head. (likely z6)
Why do you think its not kicking in?
You know it only kicks in at high RPMS right?
If so, it may be clogged.
honda1.6
Dec 16, 2008 01:41 PM
BRG+Honda=JDM
Apr 12, 2007 10:53 PM
bwr3476_ky
35
Jan 2, 2007 09:22 PM
beedoublejay
Aug 11, 2003 10:10 PM
AdamQ3B85
24
Jul 4, 2003 05:29 AM
