Need some help with alarm install into 97 Civic
Hey Alarm Gurus, I am replacing the aftermarket alarm that came with my car. It has only one remote, and it has been acting up lately, even after changing the battery for it. Anyways I dont want to get stranded after this remote gives out, so I wanted to change my alarm. I received a new paging alarm kit from a friend that bought one but never used it. (its a no name brand, but free is free) I got the wire diagram for the 96-98 civic, but i have no idea where to hook up the wires for the alarm. I was wondering if someone could tell me exactly where to hook each wire. I just tried matching the color wires from the old alarm, and its not functioning correctly.
Here is the 96-98 civic wiring colors/functions:
96-98 Honda Civic Alarm Wire Diagram:
12volts white (40A) + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow + ignition harness
Second Accessory white/black + ignition harness
Keysense blue/white to blue/red - ignition harness
Power Lock green/white - driver kick, blue plug
Power Unlock green/orange - driver kick, blue plug
Lock Motor white/red 5wi driver kick, door harness
Unlock Motor blue/red to yellow/red 5wi pwr door lock ctrl unit in driv door
Parking Lights+ red/black + driver kick, fuse box
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) green/red + steering column
Turn Signal(R) green/yellow + steering column
Reverse Light green/black + driver kick, harness to rear
Door Trigger lt. green/red - factory alarm plug
Dome Supervision lt. green/black - driv A pillar or factory alarm plug
Trunk/Hatch Pin blue/black - driver kick, harness to rear
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue ac test tachometer connector
Wait to start N/A
Brake Wire green/white + brake pedal switch
Parking Brake red/green - parking brake switch
Horn Trigger blue to gray - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Here is the wiring diagram for the alarm I have
6 pin connector:
NO orange/black
Unlock white/black
NC yellow/black
NO orange
Lock white
NC yellow
12 pin connector:
Neg black
Extinguish control yellow
Neg door inspecting blue
Pos door inspecting blue/white
Turning light 1 brown
Eng start inspecting purple
Positive red
Foot brake inspecting orange
ON inspecting white
Turning light 2 brown
Siren Output pink
Trunk release green
If somebody can please list out which alarm wire goes to which OEM wire that would be great. I dont need a trunk release or engine start, just the basic lock/unlock/alarm functions.
Thanks guys!
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
6 pin connector:
NO orange/black
Unlock white/black
NC yellow/black
NO orange
Lock white
NC yellow
12 pin connector:
Neg black
Positive red
ON inspecting white
Siren Output pink
Trunk release green
Thanks guys!
GsDAteg
Audio / Security / Video
Mar 18, 2010 04:40 AM
