Transmission & Drivetrain Gearboxes, Differentials, Clutches
How bad is bad?
Old Jul 20, 2009 | 06:05 PM
Spoon84's Avatar
Default How bad is bad?
I have JDM ITR Transmission that came with my ITR swap. Well the transmission grinds at high RPM in 2nd and 4th gear. And occationally reverse will pop out when in use.
Well I've rebuilt a few transmissions, so I know my way around.
Well, anyways I opened this tranny up the other day and noticed that the dog teeth on the gear 2nd and 4th have wear on them but doesn't look "too bad". I've never rebuilt a tranny that had this amount of wear.
The question is How bad is bad? I mean can use still use the a gear if it has wear on it after replacing the synchro's and sleeve too? Is there a way to know if it still usable and will not cause grinding?
Thanks for any info.
Old Jul 20, 2009 | 06:31 PM
mvtck's Avatar
Default Re: How bad is bad?
synchro's will cause grinding and bad gear will kick it out of gear.
Old Jul 20, 2009 | 07:13 PM
Spoon84's Avatar
Ok.. so as long as the gear was never poping out.. then most likely it just needs new synchro's
Old Jul 20, 2009 | 07:37 PM
Aquafina's Avatar
No.
Take pics and post them.
If the dog teeth on the gears are rounded, replace the gears. If the teeth on the sliders are rounded or the hubs are scratched, replace the sleeve set.
tmurphnc1985
Feb 2, 2010 05:40 AM
HondaRcB
Nov 24, 2006 11:41 AM
charjacq
Jul 27, 2004 01:13 PM
onyx00
Jul 26, 2002 06:57 PM
hybridcrx
Mar 28, 2002 04:40 PM
