93 eg have fuel, have spark, but car does not start
Old Jul 20, 2009 | 04:22 PM
drift2004's Avatar
Default 93 eg have fuel, have spark, but car does not start
i swaped out a d15b7 for a d15b8 and car cranks i have fuel, have spark, but car does not start? it almost sounds like if i dotn have enought power to crank it over, i tried a new battery with 600 cranking power and still no start, all 3 grounds on the engine are on, the tranny one, valve cover, and the battery, and the one for the harnes i have no idea im stuck any ideas?
Old Jul 20, 2009 | 04:41 PM
Anton LaVey's Avatar
Default Re: 93 eg have fuel, have spark, but car does not start
check compression
Old Jul 20, 2009 | 04:53 PM
drift2004's Avatar
good idea
Old Jul 20, 2009 | 04:57 PM
BluE-EK's Avatar
chek the harnes, maybe you are missing some sensor or connector
Old Jul 20, 2009 | 05:31 PM
not likely if he has fuel and spark
Old Jul 20, 2009 | 06:21 PM
j0keefe21's Avatar
4 things you need fuel, spark, compression, and timing. check compression and if thats good then you know your problem.
Old Jul 20, 2009 | 06:56 PM
Former User's Avatar
Check whether the timing belt slipped or snapped, or was installed such that the cam and crank are out of time. Also check whether the spark plug wires are installed in the wrong firing order on the distributor cap. Likewise check the firing order of the fuel injectors.
Old Jul 20, 2009 | 07:46 PM
drift2004's Avatar
im going to check the firing order of the fuel injectors that could be it since i did swap the harness ill have to check that out good idea!, well the motor i swaped in was sitting there about a year it was working before i took it out the original car, firing order is correct, as for timming well i can check that too can never go wrong with checking, i used the distributor from the original d157 which does not bolt on exactly to the d15 8 like i can only bolt on one, kind like when u do a ls dizzy on a b16, ill get a video up i usually can find the problem but this one is a bit more challenging lol thanks for any feedback!
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
si_motor_spt
Sep 2, 2007 06:57 PM
draw
20
Nov 22, 2004 08:33 AM
g2turbo
Sep 17, 2003 08:31 PM
chirp2hrd
Jun 8, 2003 03:15 PM
