throttle body problem
Old Jul 20, 2009 | 03:29 PM
EGR95's Avatar
Default throttle body problem
i bought a GSR tb ( its installed in a b16a) and the inside of the tb there two holes. the top hole goes to the IACV (IACV is from a GSR) and the bottom one goes to the FITV (FITV is from a GSR). the problem is that the top hole is sucking to much air, and its causing my engine to idle rough, when i notice the problem i put my finger on the top hole it started to idle smoothly,but when i take off my finger it has the rough idle. i already clean the IACV and FITV so what could it be, and i check to see if the computer was giving me a code and i obtain code 14 so i dont know what it is.
Old Jul 21, 2009 | 05:04 PM
EGR95's Avatar
Default Re: throttle body problem
any takers?
Old Jul 21, 2009 | 05:06 PM
EGR95's Avatar
ok...
Old Jul 21, 2009 | 05:09 PM
negroeg6's Avatar
Originally Posted by EGR95
ok...
If it is a obd1 gsr t/b the the valve underneath it is bad.
Old Jul 21, 2009 | 09:37 PM
EGR95's Avatar
i fix it and don't think is bad who knows i might be wrong.
Old Jul 21, 2009 | 09:44 PM
mattliston's Avatar
did you read the stickies in this forum? one is titled FAQ and in there is a thread for ECU codes
check it out, it tells you exactly what code 14 is
Old Jul 22, 2009 | 01:24 PM
EGR95's Avatar
oh its the idle air control valve, so its not working?
Old Jul 22, 2009 | 01:38 PM
Former User's Avatar
The IACV is probably bad, though you should check the wires before you replace it. What happens to the idle speed when you unplug the IACV connector?
Old Jul 22, 2009 | 01:48 PM
EGR95's Avatar
let me go check, but the thing that i dont get is why is it getting to much air from the top hole of the throttle body?
Old Jul 22, 2009 | 01:51 PM
...but the thing that i dont get is why is it getting to much air from the top hole of the throttle body?
The top hole leads to the IACV, right? So the IACV is allowing too much air to bypass the throttle body. This could be caused by a bad IACV or by a bad IACV seal. Have you checked the rubber seal?
Old Jul 22, 2009 | 02:03 PM
EGR95's Avatar
ok... this is what i did i obtain to different IAVC one was from the gsr and the other is from a d15b7 and i change the tb and put the d15b7 and i had the same results. could it be that the tb is 68 gsr + its after market part?
Old Jul 22, 2009 | 02:06 PM
Does unplugging the IACV have any effect on idle speed? If not, troubleshoot the IACV wires.
Old Jul 22, 2009 | 02:18 PM
EGR95's Avatar
no i cant tell, its still the same.
Old Jul 22, 2009 | 03:17 PM
This tells you that the IACV is not working at all. If you know the IACV is good, then check the wires. For example, does the IACV connector get voltage from the main relay when the key is in ON(II)? Do the wires between the IACV and ECU connectors have continuity?
Old Jul 22, 2009 | 03:42 PM
EGR95's Avatar
well, voltage is good and the wires have continuity.
Old Jul 22, 2009 | 03:44 PM
Then you might consider the possibility of a bad ECU. Do you have a good one to swap?
Old Jul 22, 2009 | 03:49 PM
EGR95's Avatar
well i have a good one its of my d15.
Old Jul 22, 2009 | 03:50 PM
EGR95's Avatar
but what i did notice was between the TB and IM i spared carb cleaner and the idle drop.
Old Jul 22, 2009 | 03:53 PM
Check the torque on the throttle body nuts and, if that doesn't stop the leak, then pull off the throttle body and replace the gasket.
Old Jul 22, 2009 | 04:00 PM
EGR95's Avatar
the gasket is new, and torque is tight. the leak is located at the bottom right corner.
Old Jul 22, 2009 | 07:55 PM
EGR95's Avatar
i change the idle air control valve and i dont have code 14 now i have code 22.
Old Jul 23, 2009 | 11:03 AM
EGR95's Avatar
anybody.
RotaryPWR
Jun 6, 2013 02:27 AM
TuCKiNaLL4s
Jun 21, 2004 08:31 AM
Rob!
Mar 18, 2004 02:46 PM
