Another car wont start thread...help?
Old Jul 20, 2009 | 02:21 PM
tlarimer's Avatar
Default Another car wont start thread...help?
This is on my 93 4DR EX W/JDM D15B. Let me start by saying that this only happens after it's been warmed up. Drives fine, stopped at the gas station then crank, crank, crank, wont start....waited about 15 minutes, fired right up and ran fine all the way home. Then turned it off and crank, crank, crank again. Finally got it started after about 15 minutes and checked timing, dead on. Tried swapping distributor, twice, I have 3 of them and still same thing. Tried different plug wires, same thing. Tried different plugs, same thing. WTF is going on? Is there a chance the relay for the ignition is getting hot and causing this? I am out of ideas, please let me know what your thoughts are on this problem.
Thanks,
Tim
Old Jul 20, 2009 | 02:34 PM
Former User's Avatar
Default Re: Another car wont start thread...help?
Sounds like a bad main relay. When the engine won't start, turn the key to ON(II). If you don't hear the fuel pump prime for 2 seconds, then the main relay is probably bad. Is the CEL ON?
Old Jul 20, 2009 | 02:56 PM
tlarimer's Avatar
No, I am not getting a CEL, I checked for codes before I checked timing. Where is the main Relay located?
Old Jul 20, 2009 | 03:08 PM
Old Jul 20, 2009 | 03:18 PM
tlarimer's Avatar
I will try replacing the main realy, thanks
mynameizstitch
26
Aug 5, 2012 04:33 PM
TonyBlaz
Feb 12, 2009 08:48 AM
blaxican05
Feb 23, 2008 08:47 PM
ATEJ8FTW
Sep 24, 2006 08:43 PM
Tad
Jan 3, 2006 06:37 PM
