06 SI wheel stud thread pitch issue
Good day all.
I have a small issue with my lugs/studs.
I realized the previous owner had two different type of lugs and also a lock nut.
the tire shop showed my that some of the wheel suds in the back left were cross threaded. and i checked some that 2 of the lock nuts are not tight,( htey keep spinning as i tighten it) So i look off one or two of the other lugs that seems to thread fine, but they are labeled M12x1.25. I was under the assumption most if not all Honda's come with M12x1.5 wheel studs.
Are there any cases where honda uses 12x1.25? I'm not sure if the previous owner may have changed them? i doubt though because it still has the stock OEM rims.
not that i recall. as far as i can remember honda has always used m12x1.5. the previous owner might have broken the studs and the shop that replaced them might have installed the wrong thread pitch.
seems to me that probably a person cross threaded a lot of them probably completely messed up the ones that arent suppose to be in there and then swapped them out....shady places i tell ya
743power
182
May 19, 2017 07:30 AM
hondachick81
Suspension & Brakes
Dec 2, 2005 06:45 AM
