ls/vtec oil jets
Old Aug 23, 2002 | 07:01 AM
kamciu80@aol.com's Avatar
Default ls/vtec oil jets
i am building up a ls/vtec and iam thinking about taping oil jets on the b18a block. i would use the ones from a b16 block but i don'tknow if at first it will work and second whether it willmake the block last longer.
Old Aug 23, 2002 | 07:16 AM
SpooN Man's Avatar
Default Re: ls/vtec oil jets (kamciu80@aol.com)
yes and no, What kind of pistons are you using ?
Old Aug 23, 2002 | 08:29 AM
Default Re: ls/vtec oil jets (SpooN Man)
i am think of using my b16 piston from a sir2.or any others if it will work.
Old Aug 23, 2002 | 10:02 AM
DarkSubRosa's Avatar
if your using a p30 piston i highly suggest getting a super thick head gasket to keep your compression down a little bit, the p30 pistons in a B18A block and B16A head yield like 11.8:1 compression. http://www.cspeedracing.com/howto/co.../compcalc.html
hope that helps some even though its not about oil jets.
Old Aug 23, 2002 | 10:13 AM
SpooN Man's Avatar
If your using a factoy piston then you should use the jets. aftermarket pistons will disapate heat more quickly so you would not have to use them. It does depend on the type of material they are made from.
Suprdave's Avatar
Default Re: ls/vtec oil jets (DarkSubRosa)
What's wrong with 11.8:1? Super-Thick Head Gasket? You gotta be kidding me...
Why would he wanna increase Quench Distance AND Lower his compression? That's going to cause more problems then tuning 11.8:1 Well.
Also, 93 Octane is available in the Chicagoland-area. Tuned well, and he could run 12.8:1+
Don't spread shitty info.
Suprdave
Old Aug 23, 2002 | 01:09 PM
Vanilla4215's Avatar
Default Re: ls/vtec oil jets (Suprdave)
Perhaps DarkSubRosa didn't know he could get 93 octane. Perhaps he gets screwed like all the people is Cali that only get 91 octane.
Old Aug 23, 2002 | 01:11 PM
Plan B's Avatar
Default Re: ls/vtec oil jets (Vanilla4215)
Buy forged pistons, run p30's with a p72 head, you'll have awsome compression then!!!!
Old Aug 25, 2002 | 01:50 PM
Suprdave
11.8 compression ratio on stock cast pistons?? umm, you can go ahead and do that, but im not going to risk it, I'll wait til I can get forged ones, and yes I have 93 octane.
[Modified by DarkSubRosa, 4:50 PM 8/25/2002]
J_SHADOW
May 26, 2008 06:37 PM
jdmef8vtec
Jan 15, 2007 10:33 AM
Civicr2gs5
Dec 15, 2005 02:18 PM
internet ay
Sep 12, 2003 09:10 PM
GRIMEY.STREET.RACER
Jul 22, 2002 11:35 PM
