Part throttle hesistation/stumble/misfire between 2-3K?? Any ideas
Old Jul 20, 2009 | 06:03 AM
Purple-skunk's Avatar
Default Part throttle hesistation/stumble/misfire between 2-3K?? Any ideas
Well, to fully describe the problem here goes.
At less than 1/4 throttle (about 1/8 the way down), it seems as if the car hits a stumbling block (almost as it has a misfire and seems to sound like a Subaru and just struggles to go anywhere).
What is weird however, is that of you do give it more than part throttle, the problem just goes away and the car just drives right through it. And this only occurs between 2-3 k (where I do most of my driving).
Does anyone have any ideas?? I changed the plugs not much long ago (about 6 months) but haven't checked them yet. I was also thinking TPS sensor since it seems to be throttle related, but I have not clue and do not feel like going into this blind
Thanks much
Old Jul 20, 2009 | 07:14 AM
gianinline's Avatar
Default Re: Part throttle hesistation/stumble/misfire between 2-3K?? Any ideas
I've seen something similar happening, sounded just like a boxer subaru... and the problem was electrical, battery/alternator were faulty.
How does it idle? Somewhat normal with a slight fall on the rpms or just completelly normal?
Old Jul 20, 2009 | 08:26 AM
idle is completely normal
Its definitely electric (I hope). Or something along the lines of ignition related.
Old Jul 20, 2009 | 09:07 AM
davey5300's Avatar
did u check the plug wires?
Old Jul 20, 2009 | 09:16 AM
billyrusa's Avatar
If the hesitation only happens at 2-3K RPM, it is probably a clogged EGR port problem.
Old Jul 20, 2009 | 08:32 PM
kccord's Avatar
Uuh ****, last year when my car did that (full on subaru sound) I had water on the spark plug tube which causes one or two cylinders not firing coz of the change in resistance on electrical. This happens through out the rpm.
Check the electrical section and your egr
Old Jul 21, 2009 | 11:06 AM
fu627's Avatar
Ever see the CEL come on in history?
Old Jul 21, 2009 | 11:55 AM
Nope. no cel.
I will be checking the egr port here in the next few days when I get some time.
It probably needs a tune-up................We will see.
Old Jul 21, 2009 | 12:02 PM
Ohhh, and thanks for the help guys!!!
Well appreciated
Old Jul 21, 2009 | 07:17 PM
uberEFtuner's Avatar
What year make and model is the problem car? Also what kind of mileage, and history?
Old Jul 22, 2009 | 04:51 AM
95 2.2 vtec
180k miles and pretty good history with all the papers
Old Jul 25, 2009 | 04:12 PM
Fixed!!!
EGR port (as suggested) was the problem. Looked up the how to on here and now shes running beautifully!!
Thanks much guys. Cost me all of $2.50 and about 1.5 hours (took my sweet ol time since I didnt want to break anything).
It actually feels a little better right above 3k right before vtec engagement. Part throttle misfire is gone as well as off throttle bucking.
Good day
import-tooner
Jul 19, 2013 06:39 AM
AngeloPappas900
Apr 25, 2011 06:55 AM
guywitaDA
Dec 29, 2005 10:24 PM
InfamousRS
Jul 4, 2003 01:20 PM
SIK IN DA HED
Dec 24, 2002 06:06 AM
