B20 turbo overheating
Old Jul 19, 2009 | 07:50 PM
JAYDmManny1331's Avatar
Default B20 turbo overheating
well my car has been overheating after a 5 min drive it almost got to the h on the gauge then opened the hood then smoke came out of the thermostat area leaking some coolant what can be wrong maybe my fan not turning on bad thermo im running 5 psi i have a 95 civic si radiator please help!!!!
Old Jul 19, 2009 | 08:01 PM
jmills55's Avatar
New User
Default Re: B20 turbo overheating
well my guess would be a bad thermo.....maybe a slight crack in the rad......maybe a hole in one of the hose's......check those out
Old Jul 19, 2009 | 08:12 PM
yeah im gonna check all three of those things tomorow hopefully thats the prob thanks man
Old Jul 20, 2009 | 06:14 AM
fcm's Avatar
fcm
Old Fart
There are more then a few reasons an engine overheats, loss of coolant is #1, are you constantly adding coolant?
Coolant not circulating, either thermostat, [stuck closed] water pump, [not working] or a blockage.
Air flow through rad should not be a problem when car is moving even if rad fan is not comming on so overheating would only occur when not moving.
Is the rad fan not on when engine is overheating?
Rad is too small, is it a full size or half rad?
How much of rad is blocked by inter-cooler?
Check the obvious things first, pull the thermostat and see if if engine overheats with out one.
Check temp. of upper and lower rad hoses, and let me know what you find. 94
Old Jul 20, 2009 | 07:39 AM
alright man thanks im gonna do a check up after work today im gonna take out the thermostat and try it again
killahatch
Apr 13, 2009 06:05 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
corince06
Jun 5, 2008 04:52 AM
mrx
Jul 4, 2006 07:44 AM
twenty
Jul 21, 2005 04:32 PM
