charred valves, need some advice...
Old Jul 19, 2009 | 09:22 AM
gotrice16's Avatar
Default charred valves, need some advice...
The D16Z6 in my del Sol has a burnt valve or valves in the 2nd cylinder. Its making 34 psi, where all of the others are making 160 to 165. I haven't pulled the head off fully, but my friend used a peroscope to inspect them.
Anyway, my question is, do i replace the problem valves, or do i replace all of the valves? I don't want to get screwed by the machine shop...Also, what else is necessary when valves are replaced? What else do i need to buy for a valve replacement?
Also, is this too hard of a job to tackle myself? I don't want to take on a job that is out of my league, but i am not made of money...
Old Jul 19, 2009 | 10:07 AM
SOHCNightmare's Avatar
Default Re: charred valves, need some advice...
If it were me... I would go ahead and do them all. That is if you have the money. I would replace the retainers as you go and maybe the valve stem seals if you burn any oil. GL.
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
HondaKing90
19
Feb 15, 2010 04:38 PM
1SikEagle
Sep 23, 2009 10:15 AM
junkyard racer
Sep 7, 2008 04:41 PM
flashedDc5
Oct 10, 2006 05:12 PM
