B series build help
all depends upon what you want. Luckily your in the right place! there is a ton of useful information in the FAQ section, people usually prefer the LS motor because it handles boost well, so that may be something you should look into, a mild turbo setup will really help to propel your car significantly faster than it already goes. Use the search as much as you can and if you get stuck as questions, there are a lot of knowledgeable people here
KORETSKY RACING
Nov 24, 2009 06:41 PM
