What Next? to Fix Dipping/Low Idle on GSR
what else needs to be replaced to cure dipping/LOW idle on '94 Acura Integra GS-R?
My Symptoms: 1500rpm idle after cold startup & 700-750rpm idle after warmup but, the idle/tachometer consistently drops down to 500-600rpms when coming to a stop or when coming out of gear and feels as though the engine is going to die/cut out with an erratic idle feel then will climb back up to the normal 700-750rpm idle.
what else needs to be fixed/replaced? i have listed all the parts i have fixed/swapped out so far and read every TI archive here so i would greatly appreciate any help or information especially from those that have suffered the same or if there are any honda/acura mechanics here that can help me or point me in the right direction...please! thank you.
130,000 (current miles on my '94 Acura Integra GS-R)
Checked Distributor Cap/Rotor and Cleaned/Sanded Contact Points
Checked ALL fuses to see if blown in Engine bay and Underdash fuse boxes
Checked ECU for any trouble codes but NONE displayed
Checked Ground Wires and seem to be in good/solid connections
Cleaned out Throttle Body Butterfly during IACV install and cleaned/re-oiled K&N cone filter.
131,368 BLOX Throttle Postion Sensor
127,072 Rebuilt OEM Starter @ Rite-way Electric
127,061 FITV
119,796 PCV Valve
115,000 IACV (don't clean, just replace trust me on this!)
114,441 Rebuilt OEM Nippondenso Alternator @ Rite-Way Electric
114,440 Fuel Filter
104,691 Kirkland Battery - 12.8 volts with no load & 14.4 volts while idling
95,373 Main Relay
87,617 Distributor Cap/Rotor
86,842 Thermostat
73,451 Ignitor and Coil
64,040 PCV Valve
56,961 MSD Spark Plug Wires 8.5MM
*Switched back to OEM Acura Ignition Wires (w/ 56K previsously)
51,356 Denso Platnium Spark Plugs
127,061 FITV
119,796 PCV Valve
114,440 Fuel Filter
95,373 Main Relay
86,842 Thermostat
64,040 PCV Valve
jEE
10
Mar 3, 2011 01:02 PM
