vtec question.....
Old Jul 18, 2009 | 06:01 PM
89efsiluv's Avatar
Icon6 vtec question.....
i got a gsr swap in my 89 ef.......and i think my vtec is not working......how do i know it works????????........thanx
Old Jul 18, 2009 | 07:06 PM
ryanevansoh's Avatar
Default Re: vtec question.....
well first you could approach were its supposed to engage and just see if you hear it
Old Jul 18, 2009 | 08:05 PM
BiG ChOr!Zo's Avatar
if it dont engage like this then you got a problem
Old Jul 18, 2009 | 08:56 PM
hatcht9x's Avatar
any codes? is your engine oil low? if so put enough oil in and test it again.. also it wont enguage if the engine isnt warm enough..
Old Jul 18, 2009 | 09:43 PM
placid888's Avatar
gsr swap? obd1 or obd2 i guess? 89 ef's have a mechanical speed sensor, obd1 or 2 gsr have an electrical speed sensor, remember that vtec only kicks in when all 4 conditions are met(rpm, vehicle speed, oil presure, & temperature). in this case, your vtec shouldn't be working because there's no vss input, plus check engine light is on right?
Old Jul 18, 2009 | 10:22 PM
DCRB's Avatar
with a gsr you should deff. be able to hear it engage unless you are deaf...
Old Jul 18, 2009 | 11:04 PM
D16SiHatch's Avatar
Originally Posted by placid888
All USDM ed's have a mechanical speed sensor, obd1 or 2 gsr have an electrical speed sensor. in this case, your vtec shouldn't be working because there's no vss input.
false. just because the ed chassis had a mechanical vss does not mean it lacks an electronic output. the guage cluster converts the mechanical movement of the speedo cable into an electronic pulse which is then sent to the ecu.
to the OP: like was already said, you should feel it engage. if you don't then see if you have a CEL indicating what the problem is that's preventing it from working properly. then go from there.
Old Jul 19, 2009 | 04:01 PM
aznbcu2006's Avatar
vtech are pretty subtle when they engage. or at least the ones i've heard. i really don't see the use in them, i'm more of a d16a kind of guy. turbo for life!
Old Jul 19, 2009 | 05:40 PM
89efsiluv's Avatar
thanx for the help.......
Old Jul 19, 2009 | 05:47 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yeah when I press the buttons on my Vtech Phone it isn't very loud. I want that **** to scream when I push the buttons. Where did you buy your phone, I want to hear it engage?
When I hit VTEC in my Car it pulls wheelies.
Skunk2jdmgsr
Jul 27, 2014 05:03 PM
phoxking
Mar 12, 2011 10:04 AM
89LSED
14
Nov 5, 2010 08:19 PM
OBDII Integra
Oct 16, 2009 12:06 PM
1JDMDOMINICAN
Mar 20, 2007 02:03 PM
