2001 Accord Buzzing Noise Under Car When Turned Off
2001 Accord V6 EX started making a buzzing noise under car below left rear passenger door after car was turned off (no key in ignition either). The noise continued intermittently for about 30 mins. The noise seemed to be coming from a smaller box (right next to a larger box) underneath the car, in front of the fuel tank. The box appears to have fuel lines running into and out of it. Have never noticed the noise before. Any ideas what would cause this or is it a problem? Thanks!
my wife's 01 4cyl does it regularly so i know the sound you're talking about.
no, it's not the fuel pump... the '98 and newer accords have a lot of the solenoids and purge valves for the emissions system in a cluster around the fuel tank. the noise is the sound of this system doing its job. it's nothing to worry about.
Thanks for the reply hondamark. I have never noticed the noise before and we have had the car for over 8 years. My concern was that it was the fuel pump continuing to cycle for 30 mins. or more after the car was turned off.
TweedZ
May 31, 2009 02:06 PM
