vacuum question
kind of a stupid question that i feel i should know but im not 100% so i wanna get other inputs
i have a b16a and i only have 4 vacuum ports on the manifold 1 break booster 2 fuel pressure regulator 3 PCV 4 is "open" and im using it for my map..
im trying to hook up my evap system and i know the purg solenoid needs vacuum to work so can i T in the map sensor hose to my FPR? to free up my map sensor port for the evap.. the only consern i have is that the vacuum will get messed up for the map cause of the fpr or visa versa
again it sounds stupid but im not 100% sure
i know that i dont need it however i want my system to work properly..
my main question is if i T into the fuel pressure regulator for my map will that mess with my fuel pressure and/or map signals
You should be able to put a T in one of the vacuum lines w/o any issues. As for removing the fuel vapor charcoal cannister I wouldn't because it will trigger a CEL & since you live in Chicagoland you have emissions testing FTL.
boostedcivicsir
Oct 26, 2008 02:14 PM
ef_you_again
20
Apr 12, 2005 09:42 PM
