~~~ Electrical issue with 2003 Honda Civic Si HB: Need some help ~~~
Old Jul 18, 2009 | 07:38 AM
vacantskies88's Avatar
Default ~~~ Electrical issue with 2003 Honda Civic Si HB: Need some help ~~~
We're currently having an issue with much of the vehicle lighting not coming on. So far, the front side markers by the headlights, rear tail lights, rear license plate lights, gauge cluster and dash lights on the radio do not come on. The headlights however do work.
Any ideas??? Thanks in advance
Old Jul 18, 2009 | 09:55 AM
chicoson's Avatar
Default Re: ~~~ Electrical issue with 2003 Honda Civic Si HB: Need some help ~~~
ahh same problem here. i cant figure it out. im narrowing it down to something with the alarm that was put on mine.
i also have the problem. no running lights (parks) but my brake lights work and headlights work. ive tested the switch and its fine and no fuses are blown. i can hear a slight noise quickly when i turn it to the park light position and it sounds like a relay under the dash. i dont know if there is a relay but im checking it now. ill post back if i figure out the problem. this sounds like it may be common on the EP3.
Old Jul 18, 2009 | 04:32 PM
chicoson's Avatar
ok i just fixed mine. it was 2 relays on the interior fuse panel. 2 grey bosch 4 prong relays. the 2 lower ones. i can post a pic later.
Old Jul 19, 2009 | 07:17 AM
chicoson's Avatar
here you go. i changed these relays. they were a bosch 4 prong. i hope this helps.
Juan Becerril
Classic Hondas
May 27, 2011 01:37 PM
JuniorSpades
Oct 24, 2006 11:49 AM
ChargedLude97
13
Feb 12, 2004 01:57 PM
SC0TT
Feb 11, 2004 05:28 PM
1431TypeR
Jan 21, 2003 06:01 PM
