255lph fuel pump surging when turn signal on
Old Jul 18, 2009 | 05:01 AM
projectcar's Avatar
Default 255lph fuel pump surging when turn signal on
i have a b18b1 in an eg with a walbro 255 lph pump and the pump surges when the turn signal is on. this has happened since i installed it. i have tried a larger gauge power and ground with no results. any suggestions or similar problems???
Old Jul 18, 2009 | 09:29 AM
projectcar's Avatar
Default Re: 255lph fuel pump surging when turn signal on
BUMP
Old Jul 18, 2009 | 09:31 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Have you checked the grounds on your lights?
Old Jul 18, 2009 | 09:44 AM
projectcar's Avatar
I have checked the rear and will check the front asap thanks.
egstockboosted
11
May 23, 2008 10:42 AM
TurboKneeGrow
May 9, 2008 01:17 PM
jdm206
Sep 6, 2007 02:31 PM
Green Lude 93
Jul 25, 2004 11:35 PM
ill phil
Apr 23, 2003 11:58 PM
