B series axles in civic, which ones do I have? Half Shaft
I have a 91 civic Sedan with a b16 cable trans. When I took out the drivers side axle, I was expecting a male end that goes into the half shafts as all da integras have. Instead I have a female end on the axle and a male end on the the half shaft. I want to replace my axle. Can I get this axle at autozone? If so, what vehicle do I need to get it from?
I am replacing the axle because my car is shaking under acceleration on the highway. I took out the axle and the half-shaft. I found some play in the half-shaft but I don't know if it is normal. It is not up/down play; just some play in the adjacent rotation on the shaft. Please help me out on this. Thanks
-Justin
-Justin
If you have one male axle and one female axle, it should be a gsr axles with a male halfshaft. Not sure about the newer b16 like del sol or 99-00 civic si. The gsr for sure is one male and one female
I agree^^, i would go to the junk or auto parts store to go get a DA integra half shaft.
Yea. I know that. That set wont work with an ef with a cable trans. I think im just gonna get an integra half shaft and replace the GSR axle with a male end LS/RS/GS integra axle being that DA GSR crap is not easy to come by.
