piston ring question :)
Old Jul 17, 2009 | 11:36 AM
8VEYBEYB's Avatar
Default piston ring question :)
obviously the gold ring goes on bottom with a scraper ring underneath and on top , then what order do they go in? theres an all black ring and a blakc one just like it with a silver edge , does that one go on top? this is my first time with this so advice/support/answer my question only plz n thanks.
oh yEAH I guess it would help if you knew what kinda pistons lol , they are ycp vitaras with hastings rings
Old Jul 17, 2009 | 11:45 AM
8VEYBEYB's Avatar
Default Re: piston ring question :)
Old Jul 17, 2009 | 12:01 PM
8VEYBEYB's Avatar
bump , also how do I gap them?
Old Jul 17, 2009 | 12:04 PM
elf469's Avatar
I was researching the same thing just in case no instructions came with my pistons...but i'm hopin it might help you.
http://www.federalmogul.com/korihand...section_18.htm
Old Jul 17, 2009 | 12:10 PM
8VEYBEYB's Avatar
I havent done this before and didnt realize you need to set the gapping I thought they came gapped and just put em on but I realized theres more to it than that and I need some help lol
Old Jul 17, 2009 | 12:13 PM
elf469's Avatar
i just googled this:
http://www.aa1car.com/library/ring_end_gap.htm
Old Jul 17, 2009 | 12:17 PM
4drEF's Avatar
Keyboard Humorist
Hasting has some info on their site
http://www.hastingsmfg.com/ServiceTi...stallation.htm
They also have tech support - much better than asking people on the net.
Setting gap isn't all that hard.
Make sure you have the filing tool.
You set a ring into the cylinder and press it a little ways in using a piston. This will square up the ring inside the cylinder.
Take a feeler gauge and measure the gap in the ring. File as needed.
It's a good idea to spray a little WD40 in the cylinder and on the rings to keep them from scratching.
Old Jul 17, 2009 | 12:55 PM
8VEYBEYB's Avatar
where can I get the filing tool?
Old Jul 17, 2009 | 01:18 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Jegs, Summit, Ebay, ect, ect, ect, ect, ect, ect... Just about anywhere, even places like Autozone and Advance Auto Parts can order them for you.
Old Jul 17, 2009 | 01:23 PM
DO IT ON ALL FOURS
ALSO, I HAVE ALREADY POSTED THIS USE THE SEARCH BUTTON THAT IS WHAT IT IS THERE FOR!!!!!
------------------------------------Top Ring---------------Second Ring--------------Oil Ring---------
Street/High Performance:---Bore X .0045/.005"---Bore X .005/.006"------Min .015"
Drag/Circle Track Racing:----Bore X .006"------------Bore X .0065/.007"----Min .015"
Nitrous/Turbo/SuperChrgd:-Bore X .0065/.007"----Bore X .007/.008"--------Min .015"
This Should be put in the FAQs...
Old Jul 17, 2009 | 02:40 PM
8VEYBEYB's Avatar
even if you are a tad rude about it. thank you buddy ! you guys have to realize , that when you are searching for something you dont know much about , its harder to get results , you dont know exactly what tp type ion when searching. just FYI. but thanks for posting thats a huge help.
Old Jul 17, 2009 | 04:07 PM
DO IT ON ALL FOURS
Hey no problem. Just make sure you convert your bore size from Millimeters to Inches otherwise you will come out with crazy numbers.
SoCal EJ1
23
Dec 23, 2008 02:48 PM
98vtec
Nov 24, 2007 08:50 AM
tegon-gsr
Mar 12, 2005 06:08 PM
dennis
Jan 20, 2004 08:43 PM
