Vaccum Diagram Needed for LS-Turbo in EF Civic
Old Jul 17, 2009 | 06:55 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default Vaccum Diagram Needed for LS-Turbo in EF Civic
PLEASE HELP! MORE RESPONSES & DESCRIPTION IN OTHER THREAD
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/vaccum-diagram-needed-ls-turbo-ef-2609056/
-91 B18a1
-90 Civic Si
-90 Civic Si Harness
-T3/T4 Turbo - Turbonetics
-Stock Manifold
Reading 14 in.Hg on the Vaccum/Boost Gauge
I need a Vaccum diagram for the whole setup if possible....IM to the canister...If anyone has any kind of diagrams please help.....
It starts and revs like a rotory....
already replaced IACV, MAP sensor, o2 Sensor, TPS......
if can get above 2000rpms at start-up i can rev all i want, but if not it slams 2000 rapidly and back down...
Old Jul 17, 2009 | 07:52 AM
93supercoupe's Avatar
Default Re: Vaccum Diagram Needed for LS-Turbo in EF Civic
Its not that hard to figure out the vacuum lines on any honda.Make sure everything you need is hooked up correctly, like ur wastegate, BOV, FPR, and brake booster.Once your SURE those are all getting vacuum/boost then get some brake clean and find your leak.
If you unplug ur IAC, wut does it do?
Old Jul 21, 2009 | 11:14 AM
bump
Old Jul 22, 2009 | 06:09 AM
https://honda-tech.com/forums/showthread.php?t=2609056
bump
DC2-ProdUcTiOnS
15
Jul 23, 2009 12:18 PM
Si-Samuri
11
Jul 14, 2009 09:52 AM
crxsi90ls
Dec 11, 2008 05:32 PM
89CivicHb1
Sep 13, 2008 02:44 PM
sedrohatchstyle
Dec 13, 2007 06:03 PM
