cracked manifold?
Old Jul 16, 2009 | 04:01 PM
turbo-crx's Avatar
Default cracked manifold?
how much does having a cracked manifold effect spool up? how many rpm's do you lose due to having a cracked manifold?
Old Jul 16, 2009 | 05:05 PM
93supercoupe's Avatar
Default Re: cracked manifold?
Id worry about the crack getting larger more than loosing spool time
Old Jul 16, 2009 | 05:11 PM
JDMs1eeper's Avatar
Not only can it hurt spool times, but it can hurt power as well.
its hard to say, did you buy a mani thats cracked?
If its just a fracture/hairline crack, you may not notice any ill effects. But that crack will only continue to grow. Any pictures? If its small you can cut a grove down the crack, clean it up and re weld it.
Old Jul 16, 2009 | 05:32 PM
Schister66's Avatar
Man U FTW
Just get the crack fixed...you never know what kinds of problems can occur due to it. If you had a piece of metal fall into your turbo thanks to the crack, you'd be pretty pissed. Post a pic if you can...
Old Jul 16, 2009 | 05:33 PM
turbo-crx's Avatar
its a cheap ebay manifold and the crack is very big on the #1 runner.
It is true what they say about these manifolds they crack all over the place.
Old Jul 16, 2009 | 05:35 PM
Schister66's Avatar
Man U FTW
You might be best replacing the whole thing if its an Ebay manifold...this isn't going to be the last crack you see
Old Jul 16, 2009 | 06:01 PM
turbo-crx's Avatar
im having a twinscroll manifold made now.
it has cracks around all the runners where it meets the head flange.
Old Jul 16, 2009 | 08:20 PM
m R g S r's Avatar
then it could possibly let the turbo fall off...think about it, is it worth it? just wait till you get your new mani built
Old Jul 16, 2009 | 10:20 PM
reaction360's Avatar
wait, do you have a gt4294 on an ebay manifold?
Old Jul 17, 2009 | 04:44 AM
turbo-crx's Avatar
well i just got the 4294 and have had the manifold for 2 yrs. Spool up is horrible with this manifold. I would not recommended it.
How much faster will the turbo spool with a twinscroll manifold?
Old Jul 17, 2009 | 06:41 AM
96 GSR-T's Avatar
I would think that you are aware that typically you get what you pay for, with that being said a cheap manifold that is made with cheap metal's welded and/or casted by cheap labor and sold for a cheap price is going to break long before a manifold made by decent materials welded and/or casted by a skilled fabricator that costs what a good product typically costs would (whew ), especially if it has that very heavy turbo you have in your signature hanging off of it...... I would hope that someone with a setup like yours would already know the answer to your question.
A divided manifold will spool your divided housing turbo alot faster.
Old Jul 17, 2009 | 09:13 AM
turbo-crx's Avatar
just incase someone tried to use it, i would advise against it.
Old Jul 17, 2009 | 09:44 AM
not the best comparison, but on my s372r turbo, i went from a single opening top mount to a divided topmount and gained almost 1000rpm in spool time and gained power across the board. I imagine you'll gain even more.
Old Jul 17, 2009 | 10:38 AM
turbo-crx's Avatar
thanks for your input man.
when i had the singlegate it seemed like it spooled up alot faster then when i added the second 38mm gate it seemed like the spool was alot slower. can this be possible?
RiceBurnerRebel
Dec 9, 2013 09:57 PM
Blove1991
Dec 19, 2011 06:50 PM
jdmb18b
Mar 7, 2010 09:59 PM
Boosteddb8
Sep 17, 2006 03:07 AM
