new member w/ ?'s
Old Aug 22, 2002 | 08:39 PM
projecthybrid04's Avatar
Default new member w/ ?'s
i'm gettin an ef in like a week, its a 4 spd manual, im gonna do a b16 swap in about a month, what do i need for it to be a 5 spd if i just swap the motor and connect the shift linage w/ it be a 5 spd or what??? im only 15, just starting please help
Old Aug 22, 2002 | 08:54 PM
the DR.'s Avatar
Default Re: new member w/ ?'s (projecthybrid04)
welcome to the board!
if you plan on doing a b16 swap, you're going to need a b series tranmission to go along with it, so it will be a 5 speed after
Old Aug 22, 2002 | 08:59 PM
91hatchcivic's Avatar
Default Re: new member w/ ?'s (CIVICtypeS)
wahooo!! younginz... o wait im 17, but on my 2ND CAR!
Old Aug 22, 2002 | 09:00 PM
FUP23's Avatar
New User
You need Mount ....B16 ...b serires tranny ...shift linkage re-welded or A kit ...ecu ...vtec wires o2 sensor wires and a knock sensor ...90-91 teg inter shaft ..90 -93 Integ axles ..that should have you set . Good luck
Old Aug 22, 2002 | 09:06 PM
THE *FOB* MOB's Avatar
like he said make sure u get everhthing thought...try
http://www.hondamotorsonline.com/sho...0Change%20Over
Old Aug 22, 2002 | 09:33 PM
89 CRX SI's Avatar
Default Re: new member w/ ?'s (ssr265)
hahhah 2nd car and im 16.... yeehaw.
add a turbo instead to keep alive the sohc turbos.....
Old Aug 22, 2002 | 10:28 PM
guttedEF's Avatar
Since you've got the 4-speed tranny, you're gonna have to change the hubs to fit the bigger axles. Si hubs are what you need, you can pick them up at a slavage yard for pretty cheap.
Old Aug 23, 2002 | 07:46 AM
dpo95si's Avatar
Default Re: new member w/ ?'s (guttedEF)
question about the si hubs.
will 90-93 integra hubs work on a hatchback?
seems like it would if the rear LCA's work, but does anybody know for sure
Old Aug 23, 2002 | 02:22 PM
thanks for all the help guys. do u guys also know where i can find a jdm sir front end??
jons91ef
Jun 6, 2008 10:48 AM
90civSi
Jul 14, 2005 10:35 AM
maka
20
Mar 11, 2005 08:51 PM
CRX A4
Mar 13, 2003 05:18 AM
GroundZer0
Mar 18, 2002 07:09 PM
