h22 clutch problems
Old Jul 16, 2009 | 03:09 PM
charliebcdaccord's Avatar
Icon3 h22 clutch problems
i have a 95 accord ex coupe that i swapped in a h22a1 and stock transmission and my clutch started out loosing pressure at higher rpms and was slipping and now it seems to not be releasing so it is really hard to slip into gear. the resevoir is full and i have bled it 3 seperate times please hlp
Old Jul 16, 2009 | 06:51 PM
nus_dogg's Avatar
Default Re: h22 clutch problems
How did you bleed it? You need a second person to pump the clutch pedal for a 3-5 sec and then you release the slave cyl bleed bolt for 2 sec and tighten it down then repeat the process. Thats how I did mine and always been successful(Knock on Wood).
No need to adjust your clutch pedal, I never did touch mine ever since I got it(Ever since '04).
Old Jul 16, 2009 | 08:01 PM
Icon3 Re: h22 clutch problems
I had someone in the car pumping as I bled it and I tried to bleed it again and that didn't help. Please if anyone has any ideas just let me know thanks
Old Jul 16, 2009 | 08:06 PM
nus_dogg's Avatar
Your slave or Master cyl might be shot. See if theres any leak at the master(check inside under the dash at the pedal for leaks too), if not then the slave and check that your clutch fluid rubber line isn't leaking any fluids either. Check where the clutch line hooks up to the tranny too for leaks.
Old Jul 16, 2009 | 08:15 PM
Alright thanks I will let you know if I have more questions
tercelrcr
Feb 2, 2013 06:25 AM
jdmstyleg
11
Sep 27, 2009 06:16 PM
Edul59
May 19, 2009 07:37 PM
snyderman5
Dec 26, 2005 11:30 AM
yourfacesucks
Aug 23, 2003 04:04 AM
