****B16 TRANNY PROBLEM****
Old Jul 16, 2009 | 03:07 PM
Aventuraa's Avatar
Default ****B16 TRANNY PROBLEM****
Was up guys. Have a problem with my tranny for some reason my gears I hard to go in sometymes I have to force it or let go of the cluth nd cltch in again so that the gear would go in. Please advise
Old Jul 16, 2009 | 03:18 PM
96DelSol's Avatar
Default Re: ****B16 TRANNY PROBLEM****
Does it pop out or grind?
Old Jul 16, 2009 | 03:34 PM
lovelove's Avatar
its your synchronizers. it is a very common problem on aging Hondas. best thing to fix this thing or so i heard from superstreet magazine is to go to an auto parts store and get "GM Synchromesh (friction modified) or Redline MTF," to reduce the grind. Some have sworn using these fluids have completely ended their grinding issues. Or however, if you are rich, get another tranny. But i would prefer doing the cheap thing first.
Old Jul 16, 2009 | 05:01 PM
98civdx's Avatar
Master Detailer
this is a usal promblem, replace syncros.
Old Jul 16, 2009 | 05:39 PM
ef-hatchcrap's Avatar
x2 for synchromesh took my high rpm 3rd gear grind away
Old Jul 16, 2009 | 08:00 PM
Xscort's Avatar
Before doing any of that, check your Clutch MC and make sure you have enough fluid and then bleed the slave cylinder. Before even going into the transmission, IF you do drop the transmission, it could possibly be the clutch or release bearing. I just got through replacing my clutch on my b18b. Chances are, your synchros may be wearing, but there are other probabilities before it. My clutch disc was broken which prevent me from going in gears. I'll try to post pics, otherwise, this site shows pretty much what mine did. http://www.tegger.com/hondafaq/clutch/index.html
2 of the springs were nearly about to pop out. I believe the clutch was rusted b/c it was alot of orange powder around the area. Diagnose your clutch before you tear into the transmission!!!
Old Jul 17, 2009 | 04:27 AM
Aventuraa's Avatar
does not pop or grind just as fukin mission to put in gear or take it out. at tymes i have to let go off the clutch and clutch in again so that the gear will go in
Old Jul 17, 2009 | 07:21 AM
Xscort's Avatar
Did you bleed the slave cylinder?? Stock trans? I would drain the fluid and see what comes out, and either refill with Honda trans fluid and see what happens. If things aren't doing good still, I would look into pulling the trans to inspect the clutch parts.
The Clutch M/C is working, have enough pressure?? Check in the cabin to see if any fluid is leaking back into the cabin, but make sure you bleed it first.
Old Jul 17, 2009 | 07:26 AM
Carbon Black E46's Avatar
any signs of clutch wear? loosing power at high revs or slipping? switch the fluid like the guy above me said, if it continues, you might have a shot clutch.
Old Jul 17, 2009 | 10:43 AM
Aventuraa's Avatar
Clutch is brand new has no more that 2000 miles
Old Jul 17, 2009 | 11:31 AM
sounds like a case of bad syncros than. how many miles on the tranny?
Old Jul 17, 2009 | 05:22 PM
lovelove's Avatar
check your fluids and since you said that you have a brand new clutch, possibility then it can't really be that your fluid. I am assuming that it is your synchronizers.
ls-vteccoupe
Oct 22, 2010 08:07 AM
CTR-GSR
Jul 5, 2006 01:04 AM
vtec25
Feb 1, 2006 11:53 PM
EdBoon
Apr 25, 2004 06:02 PM
