is this an easy fix?
when i bought my ej1, it had 2 cracks in the bumper. both of which are completely seperated from each other.
does anyone know if there is an easy way to fix this?
here are pics:
i also found a pic on the net that maybe could be a way for me to fix it:
thanks to anyone that reply!
here are pics:
ive seen ppl stitch fourwheeler plastics, id think it be worth a try. ive also repaired a carbon fiber bumper with fiberglass and body filled over it. looked brand new after paint!
do you thing it will hold against hard wind resistance? i never used bondo so idk the strength of it
i was thinking about the stitch idea a lil more and i thought about it and i dont really want the stitches to poke out.
but i do like the fiberglass idea. i could fiberglass behind the crack and sand and bondo on the front.
that might be a good idea
odds are, i'd be paying about 60-70 dollars here (chicago)
hard to find an ex-si bumper,
and most likely the same, if not, worse condition than mine.
plus i like to be more hands on :D so i'll probably tackle the fiberglass-bondo idea
Dude, I just did mine. Yours is TOTALLY fixable.
Push it into place and use a soldering gun to kind of melt the plastic
and create "stitches" from the back side. Then use a fiberglass kit
(they're cheap) to strengthen it from the rear. Then sand a little to
smooth it out on the front side and use filler in the cracks. A little
glazing putty if you want...then primer and paint.
It's really easy..and the truth about junkyarding is that almost
every bumper I've ever seen has cracks in it somewhere anyway. I'm
not saying you won't find one, but doing it the way I described
teaches you something and you have a little more pride in your
car because you did it yourself.
Good luck in whatever avenue you choose...
Quickridez_3
Dec 31, 2008 10:33 AM
