Changing Head Gasket On Honda CBR F2!?
Old Jul 15, 2009 | 08:36 PM
i_VTEC's Avatar
Default Changing Head Gasket On Honda CBR F2!?
Hello Honda-Tech. I'm finally replacing my head gasket on my 93 CBR F2. A local shop pulled my spark plugs off and noticed that one of the spark plugs had a little rust on it from water getting into it... Anyways hes pulling out the head and hes going to resurface it while it is off... My question is, If he resurfaces the head, Won't it cause the compression to go up? I'm sure he knows, But I was curious if resurfacing a head can cause a compression change on my motor?
Old Jul 15, 2009 | 10:30 PM
slm's Avatar
slm
Default Re: Changing Head Gasket On Honda CBR F2!?
Not enough for you to worry about. He's just going to clean up the head a bit (leftover gasket junk, etc) and we're talking a tiny amount. Don't sweat it.
Old Jul 16, 2009 | 01:10 AM
i_VTEC's Avatar
Now, While were on the subject... Does anyone know the correct compression on a 93 CBR F2? What is good and what is not? I believe my bike showed 110/115/110/120 Or something similar.... I don't remember too correctly But I do remember the Mechanic say that it wasn't for sure because he wasn't sure if each piston made a complete rotation... Then again my bike does have 40,000 miles and it has a blown head gasket... Can anyone confirm good or bad compression?
Old Jul 17, 2009 | 10:57 PM
i_VTEC's Avatar
UPDATE: Well I went to go check on my bike today and the mechanic showed me the head. It turns out that the last owner didn't want to pay the extra cash and have someone properly resurface the head. There were a bunch of grooves on the head. It looked like a dirt bike track!! He said its fixable though... Apparently that was causing the overheating problem. I'm just afraid that it might cut it close. I just don't want a valve to hit the piston dome. =/
driftingdonuts
Jun 2, 2011 02:30 AM
G2_Fella
May 20, 2008 08:25 PM
slo_hatch
10
Jan 31, 2008 08:35 PM
Nikolai
Nov 14, 2002 12:34 PM
KoRE
Jan 30, 2002 11:35 AM
