2000 Acura Integra GS-R w/Built LS/VTEC, ITR Trans, & way more
Located in Nashville, TN.
FOR SALE. No trades.
***** New price due change in parts: $8100. Comes with stock 98 Integra LS cloth seats, stock gsr shocks, ITR springs, stock brakes. ******
***** If you want the car the way it is listed, $8900 CASH. *****
Compression is 240 in all 4 cylinders as of 08/16/2009.
2000 Acura Integra GS-R w/ bulit LS/VTEC Engine (187whp) and Integra TypeR ITR LSD Transmission. The engine has 17,385 miles on it (as of July 15, 2009). There are zero problems. The engine was built and installed by myself to all specs. No corners were cut as you can see this car is clean and done right. All new OEM Honda Parts were used in the engine build with receipts for almost everything done as well as pictures. The engine was installed and started up June 6, 2008.
Engine: LS/VTEC. B18a1 Block. Bored & Honed. OEM Honda Oversized JDM P30 Pistons & Rings. All new Honda parts used for the ENTIRE engine build. New Main, rod, and thrust bearings. New ITR oil pump, water pump, tensioner, timing belt, ARP rod bolts, ITR head bolts. Complete 2001 Acura Integra TypeR ITR Head. 3-angle valve job, new valve stem seals, head was decked. Blox Cam Seal. Every little seal, o-ring, screws, etc are all BRAND NEW. I have all the receipts and pictures to prove it. All bearing clearances checked and perfect specs. Well over $5000 in parts alone. New B18a1 headgasket, oil pan gasket, valve cover gasket, NGK Iridium Plugs and NGK Plug wires. Distributor cap and rotor. Thermostat. Upper radiator hose. RC 310 Injectors. Hondata Intake Manifold Gasket. Hytech Replica Header. New Rear Main Seal. Complete ITR intake manifold, throttle body. ITR AEM Cold Air Intake. ITR throttle cable. Like previously stated, EVERYTHING in this engine is BRAND NEW. I have receipts and pictures of everything.
Transmission: Integra TypeR ITR LSD Transmission. New Axles Seals. Brand new OEM Honda ITR clutch. New Fidanza Lightweight 6.5lb flywheel.
Exhaust: Hytech Replica Header. Full 2.5" Exhaust to an 05 RSX TypeS Axle back. Flows great (2-1/4") no restriction. Comes with Carsound 2.5" high flow catalytic converter and a test pipe w/ 2.5" Magnaflow resonator that you can swap in and out if you would like.
Suspenion/Brakes/Wheels & Tires: Koni Yellow Adjustable shocks with stock ITR springs (installed March 08). Goodridge Stainless Steel Brake Lines. 2002 Acura RSX TypeS 11.8" Front Brake Calipers & new Rotors. 2001 Acura Integra TypeR Rear Brake Calipers and new 2002 Honda Civic Si 10.1" Rear Brake Rotors. Hawk HP Plus Front Brake Pads. Axxis/PBR Ultimate Rear Brake Pads. Brake fluid was flushed and new Valvoline DOT4 Synthetic fluid was put it. Brakes are amazing and stop on a dime with ZERO fade. RAYS Black Extended Lug Nuts. All new Energy Suspension Polyurathane bushings were installed in the front (lower and upper shock bushings, upper control arm pivot bushings, lower control arm bushings to frame, and big compensator bushings). Suspension and steering response is amazing. Feels absolutely amazing and feedback is perfect. 16" Konig Feather with Nitto Neogen 205/45-16 Tires with 80% tread left. 1 rim has curb rash, but not visible from the side. It's hiding where it meets the tire. Does not effect the balance or the ride. Tires will balance out 100% and come with lifetime balancing from Discount Tire Direct.
ECU/Tuning: Hondata S200 in a OBD1 P72 ECU. It was dyno tuned by Jim @ Motorvations in Trussville, Alabama on June 17th, 2008. It dyno'd at 187whp/133tq. The car was tuned with a DC sports 4-1 header. I later installed a Hytech Replica Header and a re tune, this car will put down close to 200whp if not more. I noticed a big difference as soon as I put the header on.
Audio: Alpine 9883 CD Player/Deck. Alpine TypeE 6.5inch Speakers all the way around.
More detials: I am the 2nd owner. The body has 170,500 miles. It is my daily driver, so the miles go up everyday. The car has a clean title and a clean Carfax. I have the title in hand and ready to sell. Never been in any accidents. The interior is mint and the exterior is in great shape with a few minor door dings from normal use. Integra TypeR (ITR) Front and Rear seats (black w/red stitching). I only use 93 octane non-ethanol gas and change the oil every 3000 miles. For the first 16,000 miles, I used regular Mobil1 10w-30 oil and now have changed it to Royal Purple 5w-30. It has an OEM ITR wing and OEM ITR front lip. Autometer Oil Pressure gauge and autometer gauge pod. 6000k HID High Intensity Discharged Headlight Bulbs. AEM DriFlow Filter. All new accessory belts. Skunk2 Shift ****. Everything works on the car. A/C blows cold, power steering. Car has new 15% window tint that was done in the spring.
quite trying to sell it Chris just keep and chase me around the track some more
Bumo for a good guy
car is clean and can vouch for it
Bumo for a good guy
But if I still have in the fall, I will be chasing you around the track as always. If I had tires and cash, I would love to do the time attack next weekend.
to give u the edge ill run street tires how bout that.
Yeah just got the motor running again have the roll bar installed. Just trying to make a mount for the front spliter.
U coming out next weekend to hang out?
bump for a really nice car and my old ITR tranny, now i wish i would have never sold it, that thing shifted like butter!
****** If you want the car the way it is listed, $8900 CASH. *****
92integraVTECgsr
Sep 25, 2009 05:10 PM
92integraVTECgsr
Feb 18, 2009 11:08 PM
92integraVTECgsr
Southeast (Sales)
Oct 10, 2008 12:01 PM
92integraVTECgsr
Oct 5, 2008 08:44 PM
92integraVTECgsr
Southeast (Sales)
14
Aug 29, 2008 05:46 AM
