b20 build
Old Jul 15, 2009 | 07:55 PM
i8rice's Avatar
Default b20 build
new to the honda scean, im workin with a b20 bottom and b16 head, 2 ?S would the type are cams work good with the set up and the dowl holes seem to be different any ideas ?? thanks again matt
Old Jul 15, 2009 | 08:03 PM
k20coupe's Avatar
Default Re: b20 build
Welcome to scene
There's is a lot of b20 vtec builds in this forum I suggest you start doing your homework and read all of them to get an idea
Old Jul 15, 2009 | 08:33 PM
Robierto's Avatar
I'll chime in so I can acheive my post count, lol.
For what it's worth: The holes you speak of can be remedied by golden eagle dowel adapters or you can precision drill the holes to accept the larger dowels. might want to give golden eagle a call as they have a nice full adapter kit including head gasket etc. {endyn has some nice parts as well}
As far as camshafts you will be okay running the stock b16 cams for now until you brush up on a game plan (built motor, high compression, all out build, etc...) (goals!?)
Finally If you search "how to build a b20vtec" You should find a helpful article written by Bam-bam, I think.
Hope this helps out, and hope you find what your looking for.
Old Jul 15, 2009 | 08:42 PM
i8rice's Avatar
well this is gunna be my daily drivier nice coupe i picked up for 1000 , so the head i have will work i just have to order the kit ?
Old Jul 15, 2009 | 08:54 PM
ALLxMOTOR EG's Avatar
Vietnamese!
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old Jul 16, 2009 | 06:26 PM
i8rice's Avatar
well got everthing else in today and was putting it toghter as i was putting the arp head studs in turns out the block threads are stripped, soo now looking for a short block. thanks guys for all your help and that write up is very nice.. btw any one have a b20 short block???pm me
zanottivti
19
Apr 14, 2011 06:37 PM
sick90hatch
18
Nov 18, 2008 01:19 PM
full Circling
May 22, 2006 03:17 PM
b20vtechatch
Oct 26, 2004 05:38 AM
kmf0211
Feb 20, 2003 09:37 PM
