Replaced headgasket and now car WONT START??
Old Jul 15, 2009 | 02:48 PM
jonnybadboi9's Avatar
Default Replaced headgasket and now car WONT START??
i have a 94 integra ls. Today i just got finished with replacing the headgasket on my engine... new gaskets seals.
I made sure the timing belt was adjusted correctly, but when i started the car it sounded like its trying hard to start but cant. I checked over and over when putting everything together and torqued everything to specs... all hoses and sensors connected correctly.
At the time my battery was pretty much dead so we tried jumpin it with the truck... nothing.
Over night, i recharged my battery and tried again... it sounded like it wants to just crank over but wont.. Im not sure but i think my timing could be off with dizzy.
Is there anyway to adjust or just check if its my timing when my car wont even start??
Any info would be greatly appreciated...
thanks in advance.
Old Jul 15, 2009 | 03:10 PM
mr.beeks's Avatar
Default Re: Replaced headgasket and now car WONT START??
you did not mention
any fuel
any spark
Old Jul 15, 2009 | 04:00 PM
ek-g6's Avatar
make sure your timing is correct. And that it's on the compression stroke. Like above mention, check fir fuel and spark.
Old Jul 15, 2009 | 04:01 PM
G2Integralss's Avatar
New User
make sure all your grounds are hooked up and clean
Old Jul 15, 2009 | 07:09 PM
i am getting fuel and spark as well...
I just got done checking all my wiring and grounds as well.
Everything looks good... so i can guarantee its my timing.
Tomorrow im going to take timing belt off again and adjust the crank so the 1st piston at tdc and then put belt on again and then try it.
Timing is such a pain!! lol
Old Jul 15, 2009 | 08:16 PM
googoodc's Avatar
i think its timing too, hope you get your teg runing
Old Jul 15, 2009 | 08:31 PM
ek-g6's Avatar
When you put your timing at tdc, what is the location of your dizzy rotor? When i did my friends headgasket, i mistakenly put the dizzy rotor 180 degrees the other way and that was the reason for my friends car not starting.
Old Jul 15, 2009 | 09:39 PM
rockadilla's Avatar
Ouch dude that blows.I just did that in my honda a few weeks ago and it didn't start it was actually a tiny ground wire that wasn't hooked up... U might wanna double check those once more before u try the timing belt
coltonbarrier
Feb 7, 2014 04:06 PM
Munkeyjdm86
Feb 4, 2014 07:21 AM
JDM_SOHC
23
Sep 27, 2011 04:02 PM
jimmy051702
Aug 25, 2011 04:43 PM
junya16
Mar 1, 2003 05:41 PM
