High powered FWD suspension help
Old Jul 15, 2009 | 10:37 AM
Stevefastguy's Avatar
New User
Default High powered FWD suspension help
Now I dont have a Honda so maybe Im way out off course here, but Hondas have been leading the FWD drag race scene for a long time now so hopefully Im in the right place for help.
Short story :
Im making about 750whp@2700lbs w/driver. The car traps low 150s.
I just have some off the shelf coil overs w/camber plates and solid control arm bushings. My questions are, how do I determine what spring rates I should use? How do the spring rates effect traction? Any thoughts on how to set up camber/caster etc? Right now I have the alignment set to factory specs.
Im pulling massive power out of the car the first 1/8 and I just cant seem to get in the 9s
Any help from the fast guys around here?
Thanks!
Stevie
Old Jul 15, 2009 | 10:44 AM
nasteboyii's Avatar
Default Re: High powered FWD suspension help
ill be the first to ask
what kinda car
what kinda tires
traction bars to help stablize wheels from trying to move backwards
weight and power and suspension all very important
alignment stock is not going to be the answer to drag racing. necessarly
want most weight in front end./over the tires
heavier springs in rear to make the rear end stay instead of alot of chassis movement which takes away from front tires
im rambling fast at work. all these things have been talkd bout on here. just search
and POWER IS certainly not everything
d
Old Jul 15, 2009 | 11:05 AM
miller's Avatar
A little more insight into your setup will deff be a help and we can start from there.
Old Jul 15, 2009 | 11:08 AM
lou-tdi's Avatar
I have found that simulating front end lift and then dialling the front camber in to 0.0 brought the 60' down a bit. And stopping the front end from dropping on a shift helps out. but trial and error on the allignment side won't harm you.
To fully determine what spring rates you need, I would speak to a few suspension guru's as there are lots of variables to consider.
I know the guys at progress know their stuff.
Old Jul 15, 2009 | 11:18 AM
1992Si's Avatar
Yes, call Joey at Progress and tell him what your car is and I'm sure he'll give you off the Ed. Ed's the guy you want to talk to.
Progressauto.com
Old Jul 15, 2009 | 11:56 AM
E85B18's Avatar
Traction bars help a lot in addition to coilovers. In a drag car like that I would use at minimum a 10K sprint rate, you can go upwards to 18k for example.
Old Jul 15, 2009 | 12:42 PM
tepid1's Avatar
Wrong, try again....
Old Jul 15, 2009 | 01:14 PM
lou-tdi's Avatar
haha, this could get interesting
Old Jul 15, 2009 | 01:27 PM
IT'S ME DAVID's Avatar
NooB
what about limiting straps..
Old Jul 15, 2009 | 01:59 PM
d16z6Tcrx's Avatar
ew ew ew pick me pick me! lol
turbo school 101 nuff said........
Old Jul 15, 2009 | 03:26 PM
tepid1's Avatar
This is one of the very topics that we covered in turbodano's "turbo/chassis" class this past weekend.
Limiting straps/cable
Old Jul 15, 2009 | 03:29 PM
.CUBISH.'s Avatar
whats the deal with strap or cables... ive never ran them and seen people claim they were great and other put them down
Old Jul 15, 2009 | 03:32 PM
lou-tdi's Avatar
If your suspension is done right, would straps still do anythng?
Old Jul 15, 2009 | 04:35 PM
tepid1's Avatar
There are mixed reviews indeed....
IF done right you may not even need the straps. You are correct. At the same time if done together and done right you could potentially have the best thing since sliced bread.
I'm not expert at all, but what I learned this past weekend I feel pretty educated now.
Old Jul 15, 2009 | 05:35 PM
New User
Thanks for all the replies so far guys!!
To answer a few questions I use 24x8 MH slicks. I use 9-10.5 psi in them depending on the track condition. The slick size is not a problem as I see SFWD guys running mid to low 9s on them. They are just killing me in the 330.
The launch is actually not really the problem, its after the launch to the 330 mark. I run much variable boost in 1-2nd gear but 37psi in 3rd and 4th. I cant seem to put any more power in the car down low without blowing the tires off and my 1/8 mile times really suffer.
So the main thing I need to work on is weight transfer from what Im reading. I do not want to use wheelie bars and I have thought of strapping the front end down.
I do have some very light spring rates on the car Im sure. They are just off the shelf coilovers with their standard springs.
Any other thoughts?
Old Jul 15, 2009 | 05:41 PM
Boner_Ben's Avatar
There's your problem. Try some Mickey Thompson 24.5x9's or MH 25x8.7's at 6-7 psi and go 9's!
Old Jul 15, 2009 | 06:32 PM
.CUBISH.'s Avatar
yeah youre going to want to run lower pressure on the tires. im prob going to try a set of straps on my car. Tepid pm some info if your willing to spill some info my way
Old Jul 15, 2009 | 06:42 PM
tepid1's Avatar
There is nothing wrong with sharing on a public forum.... that's how we learn, right?
Straps are nylon (generally speaking) which can be good and bad. Good in a sense that they will not hit as hard when you're extending the shock/spring combo. Bad in a way that they stretch over time and can do unexpected things. It was recommended to me to use a cable with crimp on ends. Also, placement of the strap is critical. There are different effects on the suspension if the strap is before or after the spring/shock assembly....
This all comes from just a small part of Dave Z's chassis theory. There is SO MUCH more to it.
Old Jul 15, 2009 | 09:49 PM
base-op.1320's Avatar
I always figured when the car lifted and tightened the limit straps then it would pull up on the lower control arms causing it to loose traction more, I must have thought wrong though.
Old Jul 16, 2009 | 08:07 AM
New User
I wasnt aware those tires are still being made?? Where can I buy them?
6-7psi? Wow I had no idea it was ok to run them that low!
Can anyone confirm this for me? I see that you ran mid 9s so I believe you. Would I need to run tubes to run the pressure that low??
Thanks a million!
Old Jul 16, 2009 | 08:09 AM
New User
Is there something I can read about this Dave Z?
Have any idea where I would want to place the straps [before or after spring/shock]?
I have some cables with crimped ends I will be using.
Old Jul 16, 2009 | 08:16 AM
d16z6Tcrx's Avatar
contact turbodano on here. he held the turbo/chassis class at NRG Tech last weekend. great class to be a part of. really find out whats fact/fiction.
Old Jul 16, 2009 | 08:23 AM
T76U13ALT's Avatar
What kind of car is it?
Old Jul 16, 2009 | 08:29 AM
Vw1320x's Avatar
I dont want to Hijack the thread, so to add to suspension theory whats everyones thoughts on shock valving such as dampening rate, compression, rebound speed, viscosity?
My Hot Rod car runs a set of Strange shocks in the rear and Penske shocks in the front. The car does some funny stuff when accelerating hard and I am leaning toward my front rebound being too fast. Its actually at the point where I'm scared to drive it because its almost wrecked on the last 2 outings. Does anyone else mess with this stuff or are most of you buying off the shelf preset rebound and compression shocks?
Old Jul 16, 2009 | 09:09 AM
NativeSon's Avatar
You won't get any useful info if you refuse to disclose what kind of car it is, and type of suspension. Unless its a Honda.
My suspension setup is completely different from any Honda combo, except maybe the Hot Rod cars that have converted to mac strut systems.
