new tial wastegate plumbing..
Old Jul 15, 2009 | 10:04 AM
turbodailydan's Avatar
Default new tial wastegate plumbing..
guys i got my tial wastegate plumbed in like below however the nipple that is venting to atmosphere is leaking vacuum, guessing thats not right lol can someone confirm the correct way to connect it up?
theres 5 nipples, the lower 3 are blanked off, so theres just one on the side (which i routed to the inlet manifold vac source) and the one on the top which is venting to atmo.
thanks - dan
Old Jul 15, 2009 | 10:08 AM
TiAL's Avatar
Default Re: new tial wastegate plumbing..
backwards
leave top 2 open
put the pressure source to one of the bottom ports, plug the other two
Old Jul 15, 2009 | 10:11 AM
ahh got ya. i was plumbing it like the old style tial's.
thanks matey
Old Jul 15, 2009 | 10:47 AM
TiAL's Avatar
thanks matey
this one is no diff from the previous gen aside from the two extra bottom ports and one extra top port
Old Jul 15, 2009 | 11:43 AM
thanks mate, whilst your here, is the 50mm bov supposed to be almost fully open on idle?
Old Jul 15, 2009 | 11:47 AM
dpetro1's Avatar
what spring are you using and what is your vacuum at idle?
Old Jul 15, 2009 | 11:50 AM
.7 psi spring.. erm not sure on vac @ idle will have to check. (its an AFI turbo kit, so this spring is what they sent with the kit)
Old Jul 15, 2009 | 12:05 PM
Old Jul 15, 2009 | 12:42 PM
this look right ?
Old Jul 15, 2009 | 01:23 PM
TiAL's Avatar
where is your MAF/MAP sensor located?
Old Jul 15, 2009 | 01:35 PM
on the throttle bodie why?
Old Jul 15, 2009 | 01:41 PM
TiAL's Avatar
if it's post bov it doesn't matter if it's open
if it's pre bov it needs to be shut
so you are good to go with it beign after the BOV
Old Jul 15, 2009 | 01:55 PM
thats cool, thanks again buddy.
Old Jul 16, 2009 | 08:11 AM
guys, was just thinking, is it not abit dodgy to have the bov open on idle, as its drawing in un-filtered air.. ??
Old Jul 16, 2009 | 09:30 AM
TiAL's Avatar
it's venting air out, not sucking it in
Old Jul 16, 2009 | 12:26 PM
hootiehoo's Avatar
at idle...your wrong. it sucks unfiltered air in. thats how bov's work
Old Jul 16, 2009 | 01:21 PM
TiAL's Avatar
i think we have a pretty good understanding about how a BOV works, thanks
Old Jul 16, 2009 | 03:01 PM
Blown90hatcH's Avatar
That is funny right there!
Old Jul 16, 2009 | 04:53 PM
Turbo_TONY's Avatar
Sig worthy
Old Jul 16, 2009 | 05:34 PM
Schister66's Avatar
Man U FTW
I know it's been quoted a few times already, but damn that was funny. Caught me totally off guard
Old Jul 17, 2009 | 12:54 PM
hootiehoo's Avatar
_____________________
Answered by Tial:
im sorry but a bov sucks air in at idle when its open.
Old Jul 17, 2009 | 01:13 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Answered by Tial:
Exactly, for being a company that is some poor *** attitude TiAl. You need to learn how to read; turbodailydan said its drawing in unfiltered air at idle, Tial's response is it is venting air out at idle, so good one. I don't think you know what you are talking about, it can happen both ways, loose customers much?
We all know a "Blow Off Valve" releases excess pressure. When there is a vacuum present I guess you could have the crack-head theory that it is still "venting off" negative pressure. Wow, what a different spectrum, BOVs are BOVs all the time they "vent off Positive as well as Negative pressure".
I am now a crack-head.
Old Jul 17, 2009 | 01:55 PM
Bailhatch's Avatar
Mine blows air out at idle. Some setups do suck in though, depends on how large of an opening the valve has and if the turbo spins at idle.
Old Jul 17, 2009 | 01:58 PM
LOL
ok so, is there any potential issues with the piston being open on idle..?
with having a bov spring this soft, is the bov going to be venting off on the slightest bit of boost? i dont want it ''woooshin'' like ALL the time
Old Jul 17, 2009 | 04:01 PM
DO IT ON ALL FOURS
AMEN Brother. Typically though, the BOV is sucking in air at idle rather than blowing it out on a lot of your average turbo setups.
