Swap Time and a few questions
Old Jul 15, 2009 | 06:54 AM
White99EK's Avatar
Default Swap Time and a few questions
Well after driving the stock single cam for a while now I've decided its time for a swap. The problem is anything around me is either too much for what it is or it has 90K miles or more. So I would like to purchase online from either hmotors or jhpusa.
I've looked at the b16b, but after reading numerous posts about it lacking torque and everyone wanting more power, ive decided against it.
This leaves me with either the b18c5 or the h22 euro accord motor.
Which would you guys suggest? Alot of people go the the type-r but the h22 has more hp and tq to begin with. Is there a reason you dont really see anyone running them? Is the b18c5 worth the almost $5K price tag?
Any help is greatly appreciated. Hopefully its not too redundant of a question. Even though its my first post I tried not to sound like a noob.
Old Jul 15, 2009 | 07:02 AM
zerovandez's Avatar
Default Re: Swap Time and a few questions
I'm personally a fan of the B series. I guess that's because I have a JDM GSR swap in my EK. The swap was fairly simple and straight forward. I even got it to pass BAR in CA on my first attempt.
As for the H22, I hear it does require some modifications to the shifter area for the shifter cables (I might be wrong). Not sure how it does doing up against a B series, you might want to youtube that one.
Old Jul 15, 2009 | 09:46 AM
White99EK's Avatar
The good thing about where I live is I dont have any smog tests or DEQ. I will try looking on youtube for h22 swaps. I'm just not sure if the type r is worth the extra 1000 over the h22
Old Jul 15, 2009 | 02:17 PM
94EG8's Avatar
Seagull Management
A lot of people seem to forget to look beyond the initial cost of the engine and transmission when comparing B to H swaps in civics. The upfront cost of an H22 is cheaper, however it has a lot of added costs over a B-series swap. An H22 swap requires either custom fabricated mounts or that you buy a mount kit, theres money spent, a B-series just drops in with OEM mounts. Then you have to look at axles, you need custom axles (you can get away with combinations of prelude and integra axles in lieu of buying proper swap axles, but its still going to cost more than B-series axles) with an H-series swap. A B-series simply requires B-series axles. More money spent. If you want to retain A/C and/or power steering you'll need to buy an aftermarket A/C compressor bracket for the H-series, and you'll need to fabricate some custom power steering lines. Even more money spent, again the B-series will use OEM honda parts. When it comes right down to it the H-series really isn't that much cheaper, plus you'll still have other issues like a poor axle angle on the H-series.
Old Jul 15, 2009 | 02:41 PM
White99EK's Avatar
So you think it would be better just to save some more and buy the B18C?
Old Jul 15, 2009 | 02:47 PM
ALLxMOTOR EG's Avatar
Vietnamese!
You should save money for a jdm gsr and purchase it from hmotorsonline.com.
Old Jul 15, 2009 | 02:51 PM
94EG8's Avatar
Seagull Management
If it was me thats the way i'd go. It is less power, but when its done it looks stock and its done with all OEM parts so it should be every bit as reliable as stock, in the end the big trade off is the added power of the H22 vs the reliability of the B18C5. You could also drop in a GS-R for a fair bit less and be making close to the same power as the Type R.
Old Jul 15, 2009 | 02:52 PM
White99EK's Avatar
Do you think a type-r would be worth the money over the gsr?
Old Jul 15, 2009 | 02:58 PM
White99EK's Avatar
Its going into a 99 coupe. I've been looking at all the posts in the all motor dyno thread and trying to find track times. I know anything is better than the stock single cam, but I just want to make sure its reliable and worth the money. I will be running n/a and want to keep it as reliable as possible while still being fast.
Old Jul 15, 2009 | 03:04 PM
Vietnamese!
Yes a stock R is a good all motor just bone stock.
Its all comes down to your budget.
Old Jul 15, 2009 | 03:19 PM
White99EK's Avatar
Its the initial cost that is whats hard to swallow, ya know? The complete changeover through hmotors is $2000 more for a type-r over a jdm gsr
Old Jul 15, 2009 | 03:53 PM
roadsqueegy95's Avatar
just rebuild the sohc, and turbo it! if u put the 5k for the type r into the sohc ud have a fun street car!
Old Jul 15, 2009 | 04:04 PM
White99EK's Avatar
I've thought about that, but would rather go NA. And if I really want to boost later down the road I would already have a dohc to start with then.
Old Jul 15, 2009 | 04:06 PM
Vietnamese!
A gsr would be your best bet.
esean93's Avatar
You could buy my ls swap with lowww miles.links on signature.
B series is the best way to go man!!h22s a beast but then u get the shitty shifter.if u go with h2b it's a little expensive but it's a good option.I'd just get a ls and enjoy the torque if I were u ^^^ hahahah
Old Jul 15, 2009 | 04:19 PM
White99EK's Avatar
I'm starting to think you're right. My goal is 200whp (more is always good) and hopefully high 13's in the 1/4.
Old Jul 15, 2009 | 04:21 PM
if ur goals 200whp and wanna stay n/a then id say gsr!
Old Jul 15, 2009 | 05:55 PM
94EG8's Avatar
Seagull Management
In my mind it comes down to this. If you never have any plans to build the engine then go with the type-r, if you plan to turbo, or build a high compression N/A engine then its a complete waste of money since you'd be replacing everything that made the type-R special in the first place.
Old Jul 15, 2009 | 06:17 PM
White99EK's Avatar
I'm thinking that the jdm gsr sounds like a good option. It has decent power to start with and I would have the ability to build the head and tune the ecu later this year. It comes stock with 10.6:1 CR and between the headwork and a different head gasket, it should be a little over 11:1 as I really dont want to mess with the bottom end yet.
speedyplumbing
10
Feb 22, 2010 06:10 PM
95trd
Sep 9, 2007 10:02 PM
philadd
Nov 18, 2005 03:00 PM
DownBoyDown
May 30, 2003 12:15 AM
4 Dr Swap It
Mar 14, 2003 05:42 PM
