burnin up fuel injectors
i just got a 95 eg. just replaced the distributor and the radiator. my problem now is i keep burnin up the #2 fuel injector. thats the only one i'm havin problems wit. does neone know whats wrong? is it wiring, or what?
, do you have a resistor box hooked up? i had this problem where the #2 injector stuck open. i was using chips in my ecu. i ditched the chips and used an emulator and the problem went away
